No power wont turn on
Hdtv lcd screen 20 inch, wont turn on no lights even to indicate, had to replace power cord. tried to put power cord in while plugged in hear a slight pop over and over again but wont turn on.
  • rc1916 Mar 08, 2008
    the power cord to the TV was cut. I spliced it back together but the TV will not come on.
  • 36 Answers
The Slight pop will be when the cors plug contacts the plug on the TV, and just a warning it is very dangerous to yourself and detrimental to any electrical appliance if you do this. when plugging in you should make sure everything is switched off before doing so and once all cords are connected you can then turn the power on. As to your problem I think you may have cooked your power supply inside your tv. You may need to have a technician look at it and diagnose for you. Hope this Helps.
Posted on Feb 14, 2008
Lenovo R60i wont turn on, power lights come on, go out when power button pressed
Take out the battery temporarily. Wait 30 seconds. Connect the power cord and try to start without the battery. If it comes on, put in battery while laptop is running .
Aug 01, 2014 | Lenovo THINKPAD R60I LAPTOP LCD SCREEN...
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
How can i get my sylvania netbook to work when i turn it on and it wont do anything all it does is stay at a black screen? Need help with my sylvania computer problems
When you plug in the power cord do you see any lights either on the power cord's adapter or on the computer that indicates that the power cord is plugged in? If not, your power cord might be bad. You might have been running off your battery for the last time you used it and since the power cord was bad it was not charging your battery so it eventually drained all battery power.
When you turn it on do you hear any fans running, any hard drive running, cd drive clicks once and you see the light on the cd drawer come on for a second or two, lights anywhere on the computer? If so these are signs that the computer is trying to boot. If not you might have a motherboard issue.
Static Charge Buildup can also cause the computer not to boot. Remove the power cord and battery from the laptop. Press and hold the power button for 30 seconds then put the power cord back in (leave the battery out) and try to reboot. If it boots, you had a static charge buildup and can put the battery back in now.
Is the computer actually up and running but the screen is black? If so take a flashlight and shine it on the black screen. If you can bearly see the icons on the desktop that means your lcd inverter is bad and needs to be replaced.
If the computer is actually up and running but the screen is black, try hooking an external monitor to the laptop. You can use any type of monitor, even the big fat crt monitors as long as it has a vga cable to plug into the laptops vga port. You might have to press the FN (Function Key) and one of the F1 thru F12 function keys to get the image to display. Normally the correct F1 thru F12 key will have CRT/LCD written on it or it will have an icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 Key to display the image on the external monitor. If it shows, that means your Video Card is ok.
If the computer is on and running but the screen is black, you don't see any icons on the desktop when you use a flashlight then your lcd screen will probably need to be replaced. It might be something as simple as the lCD Cable is loose or just needs reseated (pulled aloose then plugged back).
You'll have to take the screen apart to get to the lcd inverter and the lcd cables.
Mar 24, 2012 | Sylvania G-Netbook
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
How to fix a 32 inch phillips flat screen tvs that wont turn on
Tv,now turn on it don't have a power LED light at all or a blinking power LED light?The tv power supply board is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 06, 2011 | Philips 32PF5531D 32 in. LCD Television
Was watching tv lastnight and the TV just shut off. I have unplugged it for the 30 mins that it recommends for it to rest. That didnt work. Any suggestions? Thanks
Now,the tv turn on,the front of LCD screen panel the power LED light is blinking or no power LED light indication nothing at all?Yes.The tv power supply board have problems,it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Magnavox 32MF338B 32 in. LCD HDTV
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Mar 24, 2010 | LG 19LG30 19 in. LCD HDTV
Sharp LC46SB54U 46-Inch 1080p LCD HDTV Shattered LCD Screen.
it would be very expensive for replacing the screen,even the dealer won't afford that.
Mar 31, 2009 | Sharp LC46SB54U 46 in. LCD TV
My 52' vizio will not turn on
It's due for surgery to repair the power supply and or main board. One way or another it is defective but let's try the following couple steps as a work around (works for me)
Try this:
1- press power ON
2- wait 20 seconds
3- press power OFF
4- wait 20 seconds
5- press power ON.
Does it start the *second time* with the timings indicated above or never?
Feb 13, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
266 people viewed this question
Top Televison & Video Experts
