Question about Lexmark C752dn Laser Printer
Lexmark x644e Prints Smileys during the night...???
The printer prints several sheets (can even be tens of sheets) where each has couple of rows smilies/smiling face symbols. The print-outs only happen during the night time, and they do not originate from my machine. It does not happen every night, and during day time printing is normal. The problem has started before new year.
Server's event log has been checked, no print events during the nights has been logged for this printer. I have double checked printer's queue and event logs about printing and it was empty... This problem looks on some malware on the workstation side. Server is clear and also printer device seems ok.
Can you advice ???
  • Ilari Feb 20, 2008
    The printer is in a network, connected to a printer-server.
  • Adi Merschon May 11, 2010
    Hi There. Is the printer connected to one PC via USB? Is it on a Wireless Network? Has Print Server?
    Regards,
    DadFixesAll
    Genius:
  • 2,035 Answers
Use this link it may help ::
This is  lexmark site:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:530:0:0&framed=&docid=BPD1665&relevance=0
Posted on Mar 21, 2008
Had this twice on an HP PS1000, went through a complete AV / Malware scan cycle last time without finding anything, this seems a more likely explanation as the last event coincided with losing connection to printer :
http://askbobrankin.com/garbage_from_printer.html
Posted on Feb 19, 2008
    Sergeant:
  • 390 Answers
I would just run anti spyware or malware checks, and virus checks. I have avg internet, and avg antispyware, and i also have a usb stick with spybot searcha nd destroy which i only load on and use if infection is troublesome. IT is to date the only one to get rid of some really nasty spyware. I do not leave it running as i said, only the avg. There is also a free scan called housecall which will do a long deep scan and correct issues. It really sounds so typical of spyware infection. Once your pc the printer is attached to is clear it may stop.
Posted on Feb 14, 2008
201.22 code
support lexmark com Has something to do with the cartridge not being installed properly. (Not a paper jam even though the second sheet jammed) Steps to follow are at the website.
Jun 04, 2014 | Lexmark MX310dn Monochrome Laser...
Prints ok but prints additional blank sheet after each complete document
Press menu button and scroll to the right and access the Finishing menu and select NONE for Separator sheets .
Please contact Lexmark Technical Support for further assistance.
Aug 19, 2011 | Lexmark Optra T610 Laser Printer
Lexmark e260dn printer always prints an extra page (blank other than page 2 of 2). It doesn't seem to be a setting on one computer because there are several different computers that are set up to print to...
If printer is connected to network, separator sheet must be turned off. Please access the printer's web interface and click on configuration and click on finishing menu, select none for separator sheet and then click on submit.
For further assistance, please contact Lexmark Technical Support.
Jan 21, 2011 | Lexmark E260dn Laser Printer
Lexmark E350 won't detect paper. Have to open and
hi
some printers when cartridge finished do this action
(cartridg has a IC that count prints for example 5000 prints)
Jul 02, 2010 | Lexmark E350d Laser Printer
My Lexmark x1150 printer prints blank pages.
Usually, when the printer prints, but the page comes out blank, the print head on your cartridges is clogged. Since you pointed out that you computer was repaired, I guess you weren't printing during that period, so it is quite normal that the cartridges won't print. Here is a link to Lexmark's site.
http://support.lexmark.com/index?page=content&id=HO1562&actp=search&viewlocale=en_US&userlocale=EN_CA&segment=SUPPORT&productCode=LEXMARK_X1150&searchid=1270554483928.
Read carefully and follow the instructions. If necessary, do several nozzles cleaning, but do bear in mind that it uses a lot of your ink.
If you found my answer useful, please vote and leave a comment, that's what makes it all worth while!
Apr 06, 2010 | Lexmark X1150 All-In-One InkJet Printer
Have got error 1203 how do i solve ?
This means your catridges overflow, even from new catridges after several prints or right after you refilled the catridges. Follow the steps below
1) open the printer
2)remove the cartridge.
Now look - the problem is not in cartridge, the problem is in scheme from printer that touches the cartridge from behind.
You must clean this scheme from ink with a peace of soft paper ( use the kleanex for example ).
When you'll do this - let the scheme to dry for a while and after insert the cartridge. The Solution:
Use a klennex with a few drops of water to dampen and clean off the contact on the holder.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Jan 10, 2010 | Lexmark P915 Photo Printer with LCD...
CAN'T PRINT LABELS CORRECTLY
you have not set up the proper size .change settings accordingly.
Jan 24, 2009 | Brother MFC-465CN InkJet Printer
Gap in printing
the color ink cartridge has dried. replace it.
Nov 29, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark x644e LCD Display Inverted(Upside Down)
first thing i would do is update firmware
http://support.lexmark.com/static/229-1-0-530.html
Dec 18, 2007 | Lexmark X644e All-In-One Laser Printer
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark C752dn Laser Printer Logo
420 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
