Question about Zanussi FJS1225W Front Load Washer
Water pouring from detergent tray
Water pours ot of the detergent tray then stops after 1 min (ish)
only when its about to start the rinse cycle. Any clues please?
  • Deegs333 Feb 17, 2008
    Thanks! What a great service!
  • 54 Answers
Clean the dispenser and draw. now take the lid off the mashine 2 8mm nuts and remove the hose that goes to the drum and check it is clear
Posted on Feb 14, 2008
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Hi I own a Defy Automaid 600 and has never used fabric softener before. How do I go about
It's very easy- you pour it into the conditioner tray before you start the washer- like the detergent/powder- and (normally) the washer directs water into the softener tray on the (final) rinse.
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash (pre-wash detergent) and see where the water runs in, then advance to the main wash (main wash detergent) and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 05, 2011 | General Washing Machines
My dishwasher is not cleaning the dishes as well as it used to. Are there some simple things I can try before calling a tech?
Use a good quality powder detergent.
Check your incoming water temperature, 120 degrees plus.
Use a rinse aid such as Jet Dry.
Start the DW without soap and no dishes.
Once it starts the wash cycle pour in 1 quart of WHITE vinegar and let it finish the full wash cycle.
Then load up with dishes and powder detergent and run a load.
Jan 13, 2011 | KitchenAid Dishwashers
Water leaks out of the detergent tray like it's overflowing.
That happened to us when there was a piece of clothing (in this case a sock) that somehow left the drum and got lodged in the tube that feeds water into the drum. The entering water pours into and through the detergent tray, so when the tube feeding the drum is blocked, you get water pouring out of the detergent tray.
We had a repairperson come out to fix it, and he disassembled the whole thing enough that he could get at that tube and dislodge the sock. The next time it happened, I did the same thing, and managed to get it cleared as well. If you're not comfortable taking apart big chunks of your washer, it's probably smarter to let a qualified repairperson do this repair.
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
On rinse cycle, water is pouring out of the detergent/bleach drawer/tray and flooding my room. The trouble shooting guide doesn't offer any help for this problem. Washer is only 13 months old. Any...
Check the hose from the detergent tray to the drum to make sure that it is free from debris.
First take the top off by removing 2 screw in the back(Top right and Top left). Slide the top off and underneath the tray, feel around the tube to see if there is any blockages. You may have to pull the hose out.
Nov 26, 2009 | Samsung WF337AA Front Load Washer
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Aug 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Aug 02, 2009 | Kenmore Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Zanussi FJS1225W Front Load Washer Logo
99 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
