Question about Samsung ML 1610 Laser Printer
I get internal error- false
When ever i give a printout in network to my ML1610 printer,
i get internal error- false
position - ox64f2737 (105850679)
system: H6FWSIM/x1_image
line: 605
version: QPDL 1.26 04-14-2005
PLEASE HELP ME OUT
  • 3 more comments
  • Rani Foods Feb 19, 2008
    I have the same problem, except with a DELL 1600
  • davidwil Mar 26, 2008
    I get the same error message with my Samsung 1610 laser printer.
    I AM NOT ON A NETWORK.
    My printer worked without a problem until recently and I do not know what might have changed to cause this problem.
    I have reinstalled the printer driver, following advice given by Samsung.
    I was wondering about a Virus Infection although I have done a scan under DOS with advice from McAfee without finding anything.
    I have also scanned for spyware using CA antispyware without finding anything suspicious.
  • Anonymous Dec 05, 2008
    My printer is works fine when connecting to my computer. But when i plugin to pirelli wireless router, i have a problem like you.
  • Anonymous Mar 26, 2009
    same problem
  • Anonymous May 04, 2009
    2250 drukarka irgi chujova, nors per usb pajungta, įsuka popierių ir neiškiša iki galo ir kartais atspausdina tą internal error - false
DavidWil
I found the problem with my non-networked Samsung ML-1610 laser printer.
I had it plugged into a 4 way (unpowered) v2.0 hub.
When I plugged it directly into a USB port on the computer the printing error disappeared.
Posted on Mar 29, 2008
I have the same printer, I found if I plug it directly into the computer rather than through the 4- way USB hub, all problems disappear! (For now...)
Posted on Apr 11, 2009
    New Friend:
Internal error - FALSE
position : 0x3468f3 (3434739)
system :H6FW/xl_image
line : 482
version : qpdl 1.26 05-06-2004
Posted on Jun 11, 2013
If i not mistaken you need a printer server.
the printer will not work properly if you desktop is connected wirelesly to the internet.then, you laptop is connected to your desktop wirelessly also. One conputer must be connect to a cable to make the conputer work properly.
try this....
connect your desktop thru a cable modem, not wirelessly.
then locate your printer using your laptop...it should work.
Posted on Oct 10, 2008
  • compfreak010 Oct 10, 2008
    the cause of this problem is the printer cannot transfer the proper file thru your desktop wirelessly.
    I actually had the same problem...bought a desktop and a laptop...both have the capability to connect to the internet wirelessly, but having trouble printing....
Chujowa ta drukarka
Posted on Jun 04, 2008
It is a problem with printing a specific type of document. In perticular a LARGE document (lots of pages, or lots of pictures). Its not spooling the document quickly enough and is causing a failure. Go into the network settings and set the network speed (if your using accross the network) and set it to 10Mbps full.
Posted on Feb 29, 2008
Two differents internal error
The cable could be Faulty replace it with a new or known to be working fine .
Jun 25, 2015 | Samsung SCX 4200 All-In-One Laser Printer
Hei, need help when printing from Samsung Galaxy Tab 10.1/Polaris Office app to Samsung printer SL-M2070W: SPL error code 11-1113 position 0x0 system h6fwsim/xl_image line 398 version spl 5.73. Thanks in...
I am trying to print via wi-fi direct, and it gives me:
SPL ERROR -Please use the proper driver
POSITION 0x0
SYSTEM h6fwasim/x1_image
LINE 398
VERSION SPL 5.73.04 06-10-2014
ERROR CODE 11-1113
Any help?
Oct 10, 2013 | Office Equipment & Supplies
INTERNAL ERROR - FALSE POSITION: 0x3aC5a4e (3851684) SYSTEM: H6FWSIM/xl_image LINE: 605 VERSION: QPDL 1.26 04-14-2005
Aug 05, 2010 | Samsung ML 1610 Laser Printer
Printing error
I had the same error message printed with the same printer. I solved my problem by printing my PDF document with another program.
Jul 03, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Whats the problem in my printer the online error in samsung printer ml 1610
Por várias vezes, quando tentei imprimir um documento na Samsung ML-1610, saiu apenas uma folha escrito assim:
POSITION: 0xa45ae (673198)
LINE: 605
E não imprime o meu documento. O que pode ser feito?
Mar 23, 2010 | Samsung ML 1610 Laser Printer
INTERNAL ERROR - FALSE POSITION: 0x74830 (4777232) SYSTEM: H6FWSIM/xl_image LINE: 467 VERSION: QPDL 1.16 10-29-2003
at http://www.adassoft.com/en/linux/235-instalar-impressora-scx-4200-no-opensuse-110.html this problem is mentioned (on a suse 11.1, using the samsung-drivers) - the author thinks it's related with koffice - i have the same problem on a mandriva spring 2009 linux with samsung scx-4200R, but printing out of kooffice works fine for me, okular and thunderbird show me the above error (with version qpdl...2005). So far I've no idea how to fix that...if you use linux, one problem may be that first you need to install cups and sane, then the samsung driver packages.
Jun 09, 2009 | Samsung ML 1710 Laser Printer
Xerox WC Pe16 ask for solution for Internal error false... line 226
POSITION: 0x4364c (276044)
SYSTEM: H6FW/xl_image
LINE: 495
VERSION: QPDL 1.40 11-14-2005
Jul 03, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Internal error
We received a similar problem on ours:
Internal Error - False
Position: 0x268f3b (2527035)
System: H6FW/xl_image
Line: 476
Version: QPDL 1.22 12-02-2003
We would also like to know exactly how to fix this problem as it doesn't seem to work at all now!
Dec 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
My computer restart when I print something
Reinstall the printer drivers. In your case, I recommend erasing completely the previous driver so you do not overwrite on them. This is just in case you have a bad sector in your hard drive, we do not want to reinstall over a bad sector. After the driver is erased, check your hard disk with the scandisk or chkdsk utility. Then reintall your driver from start.
Sep 11, 2006 | Samsung ML 1610 Laser Printer
Samsung ML 1610 Laser Printer Logo
5,842 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
