Question about Verbatim Corporation Wireless Travel Mouse,800 dpi,RT/LF Hand,3-3/10"x2"x1-1/5" (VER95210)
Batteries how do you put the batteries into the super mini RF wirless travel mouse dc 3v---35mA thanks
  • verycurious Feb 29, 2008
    There are no instructions on how to replace the batteries on this mouse. In fact there are no instructions at all.
  • Anonymous Mar 13, 2014
    I recently put new batteries into my 49034 mouse and the red light that flashes under the middle scroler, that I assume indicates low battery, has begun flashing just a few days after putting the new batteries in. Surely the mouse can't chew the battery power that fast?
    President:
  • 8,637 Answers
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 20, 2009
This worked great, however, it would not slide back for me. I stuck a letter opener behind the Left and RIght keys and it popped right off.
Posted on Apr 10, 2009
How do I fix my mouse? It won't work.
if the mouse is wireless, why are you plugging in a usb?
Jul 25, 2015 | Case Logic Mini 2.4GHz Wireless USB...
Camcorder broken , How to remove tape?
Hey,
I have the same problem and I found this fix in a service manual. It worked, but my tape motor adjustment is off. So be carefull.
The 3v dc is easy to make, connect 2 batteries 1.5v in serial, you get 3V dc.
Let me know how it goed.
Jan 23, 2012 | JVC GR-D350 Mini DV Digital Camcorder
I had a super mini RF wireless mouse given to me, but wasnt told how to use it. Can u please tell me how to get it started.. Ive put 2 aaa battery and pushed the reset bottoms.. but its just not...
Connect the USB adapter that should have been included into one of the USB ports on your PC, as you need this adapter to use the mouse.
You will also need the driver for the device which should also have been included, if not you can go to the manufacturer website and download the driver.
The mouse will NOT work without the adapter, so if it was not included the mouse is useless to you.
I hope this helped.
Good luck and have a pleasent day.
May 31, 2011 | Computers & Internet
Can't get the verbatim super mini RF wireless optical to work
There should either be a paring button on each device or at least one of the. According to the website there is no need for 3rd party drivers so technically yes it is plug and play. As for the disk - I think it is a DVD disk and you have only got a CD rom - otherwise spray the disk with window cleaner like Windex. I have tried this and it works -makes the disk easier to read. Also don't discount good old saliva [ I know - who knew] - making the disk readable mean you must have a DVD player if that is what the install disk is.
May 03, 2010 | Computers & Internet
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
Mar 08, 2010 | BenQ M310 Wireless Mini Optical Mouse
My wireless mouse will not work, I forget how to 're'-pair it. It was functioning normally before i left home for a couple of days. Both the mouse and the other part (that goes into the usb port) are...
1. Try unplugging usb device and replugging in (I'm sure you already did that) LOL
2. Uninstall device driver
3. After uninstall plug in USB device
see if that works
Nov 14, 2009 | BenQ M310 Wireless Mini Optical Mouse
Difficulty getting my mouse to communicate
Normal 0 Turn the mouse over and find the small rest/connect buttonon the bottom of the mouse and press it. This should connect the mouse tothe receiver and work properly. If not, try pressing the receiver buttonand then press the button on the mouse. This should be done whenever youchange batteries or glitch. Hope this helps you. Bud
Nov 21, 2008 | FMI Mini Wireless Optical Mouse with Slim...
Jvc gr d290
Just remove the cover and connect 3v dc supply to the loading motor opposite way the motor will work reverse and cassette will come out and then fix back every thing as it was and then put a new cassette.
May 12, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Verbatim Corporation Wireless Travel Mouse,800 dpi,RT/LF Hand,3-3/10"x2"x1-1/5" (VER95210) Logo
281 people viewed this question
Top Verbatim Computers & Internet Experts
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
