Question about Samsung SGH-A877 Impression Cell Phone
My screen freezes and I can't do anything with it involving the screen..shut down and battery removal doesn't resolve...can't access any functions with screen, totally frozen.
    New Friend:
  • 11 Answers
Mine did the same exact thing. my first impression (that i only had for 3 1/2 months) decided to completely freeze the touchscreen, when i had absolutely no water damage and had never dropped it. i tried EVERYTHING took out the battery and the sim for an entire day, turned it on and off, and nothing worked. One thing i know, try your best not to drop this phone because my friend also had to get a new one because she dropped it several times, and they are VERY sensitive, and dropping it throws off the calibration, as does getting liquid on the screen. I went to a local at&t store and they said I would be eligible for a new phone because I had not caused the phone to stop working, but they could not give me one at the local store. i went to a DSC (device service center) for at&t, and the guy took one look at my phone, tried to play around with it, and within a couple minutes said I would be receiving a new phone that day. I received a new phone, and even got my numbers and my sim transferred for me. if your phone continues to freeze up, definitely bring it in. hope this helps :)
Posted on Feb 28, 2010
Testimonial: "exactly the problem I had..."
    New Friend:
Hi, it seems that your device need a software update by removing previous software. goodluck......
Posted on Jan 21, 2010
SOURCE:
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Screen freeze after soft reset
Hello
did you remove the battery ? Shut off it and the remove the battery some freeze can be resolve like that. if not may be you need to update the firmware of the phone.
melnavz
Apr 01, 2008 | Samsung i760 Black Phone
My phone doesn't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 10, 2012 | Cell Phones
Stuck on start up screen, will not go to home screen
5.Wait 10 seconds.
Step
Thanks
Nov 03, 2012 | Virgin Mobile - Lg Optimus Elite Mobile...
My phone wont turn on
5.Wait 10 seconds.
Step
Thanks
Sep 05, 2012 | HTC Vivid
Touchpad freezes
Control panel - find mouse/touchpad icon and try a reset of the functions. If all else fails and you can back everything up, a clean re-install of Windows should solve it. If that doesn't work, it's a hardware problem - return to Sony or a qualified engineer
Dec 28, 2011 | Sony Vaio VGN NR21 Laptop Universal AC...
Since a week ago, my laptop was working normally but every 30 minutes, it freezes but itself, so I have to shut it down and restart it again. Then at late-night i was watching a video on YouTube, the...
If you are not seeing even the BIOS screen when you turn on the laptop then it is possible that an internal component has failed which gives you very few options.
1. Try removing the battery and starting the laptop with just the mains charger connected - this will help eliminate a battery failure issue.
2. Try connecting an external monitor and see if anything appears on that display when booting the laptop - this will eliminate the laptop display.
3. Check how many memory modules you have installed on the laptop, these are normally accessible beneath a small cover on the base of the laptop - you may have to undo one or two screws to get access. If you have more than one memory module, then remove one module and try starting the laptop with only the other installed. If that doesn't help, then try with the other module removed and the first replaced. This will eliminate the memory. Note: please be very careful when handling memory - do not touch the components on the modules, hold only by the edges and try to ground yourself if possible to prevent damaging the components by static electricity off your clothing etc.
4. Try booting from a CD or DVD (you could use a Windows install or recovery disk, or a Linux Live CD for such as Ubuntu, or a rescue type CD such as Hiren's Boot CD) - this will eliminate a hard drive failure or corruption though it seems unlikely this may be the case given you cannot access the BIOS panels. You could also try removing the internal hard drive and repeating this test.
If all of the above do not move the problem forward, then it is likely that you have got a more serious problem with such as the processor or motherboard or integrated components of the latter - you would need to get service from Medion or a local PC repair shop.
Dec 23, 2011 | Computers & Internet
I can't shutdown my laptop.
If you can't shut down normally (using windows), you can press and hold the power button until the computer shuts down. You can also remove the battery.
Make sure to save you work or anything that is open before you perform a hard shut down.
Feb 28, 2011 | Lenovo Computers & Internet
I press power and the lens opens and shuts but dows not allow me to take picture. The screen reads ''tune the power off an on again'' but turning powers on/off does resolve anything.
Hi!
You may try removing the Battery from the Camera then press and hold the power button for 30 seconds. Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery pack is fully charged. Next, check if the Menu options or home screen is accessible. Then try resetting the Camera to the original factory settings.
If the issue persists even after performing all the above steps then service is required.
Aug 24, 2009 | Sony Cameras
Computer Freezes
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Samsung SGH-A877 Impression Cell Phone Logo
506 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
