Question about Kenmore 24 in. 15932 Built-in Dishwasher
Quick Rinsw button blinking
Kenmore 665.15712000, I have Kenmore 665.15712000. Diswasher is not working at all. If I pess all the button then only "Pot and Pans " and "Quick rinse" buttons blink then If I press Cancle button. "Pot and Pans " stops but "Quick rinse" and cancel buttons starts blinking. If I open and close the door, Cancle stop blinking but "Quick rinse" is still blinking.
Could anybody pl help me
  • 2 more comments
  • Anonymous Feb 15, 2008
    cannot start cycle. air dry blinks as soon as door is closed. pushing on cancel adds quick rinse light. holding down lock doesnothing. John
    665.15824
  • Blogger Feb 16, 2008
    I tried pushing 'Start' Button but nothing is happening
  • robert samples May 11, 2010
    try turning the power off for a few minutes make sure the option buttons are pushed the same as the cycle you are using if you select heavy wash then heavy wash option must be selected the manual says buttons flashing are a sign of a stuck key pad some times you can get to the control there is a mylar ribbon that you pull uo on a plastic piece to unlock it where it goes into the control and clean the end of it with a pencil eraser and that will fix it also where the black wire goes into the electronic control is a fuse it doesn't look like a fuse but it is need to check it to make sure its not blown
    try pushing start resume and advise me
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Posted on Feb 04, 2009
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
We have a Kenmore dishwaher model#665.15772990 the no heat dry light was flashing and we could not get it to reset. So we replaced the board. It has been 1 month and now the quick rinse light is flashing....
sometimes it is because of a stuck button, push-tap the buttons
and see if it does anything otherwise sorry.
here's a link if you need it.
http://www.applianceblog.com/mainforums/threads/38660-kenmore-665-15632000-blinking-quick-rinse-light-after-replacing-control-board
Dec 31, 2017 | Kenmore Dishwashers
My kenmore HE diswasher, model number 665.1312 won't dry
is your heating element was working?,if working check the blower if working too.
Jun 04, 2010 | Dishwashers
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button...
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Jul 16, 2009 | Kenmore Dishwashers
Diswasher will not do anything...
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Apr 21, 2008 | Kenmore 15919 Built-in Dishwasher
Kenmore Dishwasher 665.15895793
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Jan 12, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 74362
May 14, 2007 | Kenmore 16919 Built-in Dishwasher
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 15932 Built-in Dishwasher Logo
363 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
