Dual Monitor I want to setup a Dual Monitor Setup. I have one ASRock KMVM3 mother board which has 1 AGP Slot and ASUS V3800M/32M Graphics & Video Accelator Card. When I add this card, system works fine but OnBoard AGP becomes invisible. What setting I should use so that I can setup a Dual Monitor System?
  • Koushik1 Feb 13, 2008
    Thanks dileep007 for your commets,
    It is still not happening here. After I connect AGP Card on the slot and a monitor, then Switched on the system, It is detecetd and installed the drivers properly and display was comming properly in new Monitor. But I did not find any option Like Identify in Display Property. Next I restarted the system and went to Setup and Made OnBoardAGP as primary display. Then the system started with display in original monitor. I checked Device Manager, The V3800 AGP is not detected now, here is the screen shot.
    Device Manager
    I checked Display Properties (above screen shot) It shows 2 monitors but both are same. I can do whatever options you said, other monitor remains blank.
    What can be the problem? ..... How to solve it
  • vasu200442 Jul 21, 2008
    I am using a original intel motherboard and geforce 6200 graphics card. i need a dual monitor display. On board VGA will run until the graphics card is not placed and when the graphics card is connected it dissappears.
    So please find me a better solution.
You don't use the onboard + the AGP graphics card. You use the dual monitor capability of your new card. Plug both monitors into your AGP card, then you'll be able to follow those other instructions to extend your desktop on to the second display.
That graphics card has a VGA port and a DVI port - so one of your displays will need to use a DVI cable (or you might need to get a VGA to DVI adaptor)
Posted on May 22, 2008
  • 983 Answers
To arrange multiple monitors
This procedure applies when two or more monitors are connected to one computer.
  1. Open Dual Monitor - shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Identify to display a large number on each of your monitors, showing which monitor corresponds with each icon.
  3. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
note.gif Notes
  • To open Display, click Start, click Control Panel, and then double-click Display.
  • The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Posted on Feb 13, 2008
  • 5 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 13, 2008
    To change the
    number of colors on multiple monitors
    computer.
    1. Open Display in Control Panel.
    2. On the Settings tab, click the monitor icon that
      represents the monitor that you want to adjust.
    3. In the Color quality list, click a color setting, and then click
    Notes
    • If you click the icon for a secondary monitor, the Extend my
      Windows desktop onto this monitor
      check box must be selected to change the
      settings for that monitor.
    • Click Medium to display over 65,000 colors, High to display
      over 16 million colors, or Highest to display over 4 billion colors.
      Choosing more colors provides better color quality on your screen.
    • Settings that display a larger number of colors normally require more
      computer memory and might affect performance on older computers.
    • Your monitor
      and video adapter determine the
      maximum number of colors that can appear on your screen. You can specify the
      color settings for each installed monitor.
    • Changes to screen resolution affect all users that log on to the computer.
    computer.
      Apply.
    4. Drag an item on your desktop across your screen until
      it appears on the alternate monitor.
      Or, you can resize a window to stretch it across more than one monitor.
    Notes
    • The arrangement of the icons determines how you drag items from one monitor to another. For
      dragging left and right, arrange the icons side by side. To move items between
      monitors by dragging up and down, position the icons one above the other. The
      arrangement of the icons does not have to correspond to the physical positions
      of your monitors. You can place the icons one above the other even though your
    To install
    additional monitors
    1. Turn off your computer.
    2. Insert your additional Peripheral Component Interconnect (PCI) or
      Accelerated Graphics Port (AGP) video adapter into an available
      slot.
    3. Plug your additional monitor into the card.
    4. Turn on your computer. Windows will detect the new video
      adapter and install the appropriate drivers.
    5. Open Display in Control Panel.
    6. On the Settings tab, click the monitor icon that
      represents the monitor you want to use in addition to your primary monitor.
    7. Select the Extend my Windows desktop onto this monitor check box,
      and then click Apply or OK.
      If the check box is not displayed on your computer, it may be because your
      video adapter does not support multiple monitors. See Notes for
      information about compatible hardware.
    Notes
    • Selecting the Extend my Windows desktop onto this monitor check box
      allows you to drag items across your screen onto alternate monitors.
    • To use the multiple monitor support feature, you need a PCI or AGP video
      adapter for each monitor. If you have an onboard video adapter (one that is
      not a plug-in card but is part of the motherboard) that you want to
      use as part of a multiple-monitor configuration, it must be set as VGA.
      To find hardware that is supported by Windows operating systems, visit
      the Windows Catalog on the Microsoft Web
      site.
    • If your computer doesn't recognize your second monitor, click Display Troubleshooter for
      more information.
    • The operating system always needs a VGA device. The computer's BIOS or EFI
      detects the VGA device based on slot order, unless the BIOS or EFI offers an
      option for choosing which device is to be treated as the VGA device.
    • The VGA device cannot be stopped, which is an important consideration for
      docking units.
    • The monitor
      that is designated as the primary monitor will display the logon dialog box when you start
      your computer. In addition, most programs will display windows on the primary
      monitor when you
      initially open them.
    • If you are using Dualview, skip steps 2 and 3 above. Just plug your second
      monitor into the
      video out port on your portable computer, or into the second video out port on
      your desktop computer. When you turn on your computer, it should recognize the
      second monitor.
      Follow steps 5 through 7 to extend your display to the second monitor. If the second
      monitor is not
      shown on the Settings tab, you might need to update your display driver.
    To view the
    same desktop in multiple monitors
    computer.
    3. Select the Extend my Windows desktop onto this monitor check box.
    Notes
    To change
    your screen resolution when using multiple monitors
    computer.
      represents the monitor whose screen resolution you
      want to change.
    3. In Screen resolution, drag the slider to set the resolution you want
      to use for the selected monitor, and then click OK or Apply to view
      changes.
    Notes
    • If you click a secondary monitor and the Extend my Windows desktop
      onto this monitor
      check box is not selected, you cannot change
      the settings of that monitor.
    • A higher screen resolution reduces the size of items on your screen and
      increases the size of your desktop.
    • Each monitor
      has its own screen resolution settings.
    • Your monitor
      and video adapter determine how
      much you can change your screen resolution. You may not be able to increase the
      resolution above a certain level.
    To change the primary monitor
    computer.
      represents the monitor you want to designate as the primary one.
    3. Select the Use this device as the primary monitor check box.
      This check box is unavailable when you select the monitor icon that is
      currently set as your primary monitor.
    Notes
    • This procedure is intended for people using multiple monitors. If you have
      just one monitor
      attached to your computer, you do not need to designate the primary monitor. Click Related
      Topics
      for information about installing multiple monitors.
    • The monitor
      monitor when you
    this detailed description will help u ....
Is there always a free slot for a video card on motherboards that have integrated video cards
Most motherboards have expansion slots, you need to identify the type of expansion slots that are installed eg. PCI. AGP etc.
If your motherboard has an AGP slot (this slot is for graphics card) then purchase an AGP graphics card.
You may need to disable the on-board graphics card in the BIOS setup.
Mar 21, 2012 | HP Pavilion Computers & Internet
I am putting together an ASRock mobo. I am told NOT to use a 3.3v AGP card. as it will damage the board. ASRock K7S41 / K7S41GX. N Videa replys are not specific. I have 3 AGP video cards and have no idea...
Hi, you can download a manual here:
Your mainboard has AGP slot.
  • 1 slot for AGP 8X/4X 1.5V
  • http://www.asrock.com/mb/overview.asp?Model=K7S41GX
    http://www.nvidia.com/page/geforce2mx.html
    The to first one is AGP.
    The last one is PCI-E
    Graphics Processor: NVIDIA GeForce2 MX 200
    NVIDIA Model Number: 8859
    Memory: 64MB
    Outputs: DVI
    Interface / Slot Type: AGP
    • Installed Memory: 32
    • Interface Type: Video - 15 pin High-Density D-shell (VGA)
    • Video Chipset: NVIDIA GeForce2 MX400
    • Slot Type: AGP
    GeForce MX4000 Bus Type PCI Slot Memory on Board 64 MB DDR RAMDAC Support 270 MHz Max. Resolution 2048x1536 8/16/32 bit colors with 60Hz (Analog) Memory Interface 64-bit Display Output Dual VGA
    (1x On-Board VGA,
    1x MD9-pin port supports 1 x VGA) Operating System Support Windows® XP/2K/98//Me/NT 4.0
    Aug 28, 2011 | Asrock K7S41GX Motherboard
    No display on monitor & if ram open and restart on then no sound on buzzer.
    *Please Read full post before trying Also download the Online manual for this motherboard it takes only a minute and probably will answer a lot of questions you might have regarding *********** Board.*
    Um... i am assuming your able to still see the display on the monitor if you plug your monitor into the on board video card. I am also assuming that the problem your talking about accursed when you plug in a video card into *********** board and then plug your monitor into that video card. I am also assuming your graphics card that you want to plug into *********** board is a AGP slot card.
    If both of these conditions apply to you then try this.
    Start your computer with your on board graphics card and unplug any other graphics card form *********** board.
    Next go into your bios, and follow these instructions:
    Go to "Advanced", "Chipset", And then "AGP configuration".
    Next change your "Select AGP 3.0 Data Ratio" to "4X".
    Next change your "Graphics Adapter Priority" to "AGP/Int-VGA"
    *make sure its set to" AGP/Int-VGA" or your display will not work and you will need to reset your bios via the mother boards jumper cables.*
    After that hit esc and go to "Exit" select "Exit
    Sep 24, 2010 | ASUS K8S-MX Motherboard
    Help me.After lighthning, my asus lcd monitor turn to yellow(until now).I'm not sure is it because of graphic card or my mother board.
    if your pc wont display after the installation. the problem is centered on your video hardware. try to install the driver of your video hardware.or go to the bios setup menu then system performance down agp aperture increase the number if your using agp video cards it will help you.
    Mar 21, 2009 | ASUS LCD Monitor
    Which latest Graphic card can be supported by my Asrock P4i45GV?
    Hi
    Any video card that supports AGP x8 Should work on this motherboard.
    For example Nvidia 7800 GS AGP or 7600 GS AGP should work fine.
    But a better investment would be to upgrade the motherboard to a PCI-E supporting board and possibly AMD Dual or Triple / quad core processor the ram is very cheap for DDR2 these days.
    Upgrade would be best in long run.
    Feb 02, 2009 | Asrock P4I45GV R5 Motherboard
    I have asus MB P5PE-VM in ,y computer. After using it for sometime it there was no more video display. the monitor indicate no signal. No beep sound. only the hard drive indicate that it is busy due to...
    Have you tried another monitor? Have you tried reinstallng the videodriver?
    If none of that works your model has an AGP 8 video card slot(Advanced Graphics Port). Purchase a AGP card and it wil come with the driver. Turn off the "onboard graphics: in the BIOS setup screen and you off and running again.
    Asus link is to *********** board. http://www.asus.com/search.aspx?searchitem=1&searchkey=P5PE-VM
    Jan 29, 2009 | ASUS P5PE-VM Motherboard
    I want dual monitor for my PC
    simply install another video card or get a card that has two outputs no pc will work with more than two video cards but the best setup is 1 on main board and one in the agp slot . or 1pci and 1 agp then enable them in your display settings :)
    May 28, 2008 | Computers & Internet
    Graphics card problem
    Hi rovin,
    So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
    You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
    The only slot you're board does not have is a PCI-Express.
    Look in you're manual on page 1-7 for the location of the AGP video card slot.
    94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
    The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
    If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
    http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
    I hope you find this helpful.
    Mike
    May 11, 2008 | ASUS P5PE-VM Motherboard
    Video card
    actually your computer is working on the onboard video adapter.
    1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
    2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
    so that you can enter to bios setup.
    3. if bios setup is open; try to find the "AGP bridge configuration"
    (some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
    4. Find " primary graphics adapter"
    5. In there, select : If Video card is "pci" connected ; select "pci"
    If Video card is "AGP" connected ; select "AGP"
    6. press F10 to save and exit the setup.
    7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
    Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
    hope this help.
    Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
    Computers & Internet Logo
    1,674 people viewed this question
    Alun Cox
    David Payne
    David Payne
