Question about Samsung TXN3298HF 32" TV
Fuse blows when the dgausing coil is connected
Any guess
  • 2,130 Answers
If the fuse is blowing when the internal degaussing coil is connected, there is probbaly a shorted turn or multiple turns in the coil. A degaussing coil is made up of many feet of wire, wound in a circle around the perimeter of the picture tube.
When you first turn on the set, the coil is energized briefly and either a thermistor or relay shuts it off after a few seconds. If it didn't shut off, the coil would get very hot. When its activated, the set draws a fair amount of current because the resistance of the wire is low. You can actually hear the buzz on a TV set or monitor when the coil is energized and you can also hear it turn off.
If the normal resistance of the coil has changed, due to shorted turns or something nicking the coil, there will be a larger amount of current draw and the fuse will blow.
Maybe the circuit that shuts it off was defective and the coil stayed on and became damaged.
If the set works fine without the coil, then something has changed in the coil and that tells me that its resistance is now lower than it should be, or its somehow it shorted to ground.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
Cadilac srx 2005 blowing even coil fuse 15a everytime you turn the switch on
That fuse also powers the even fuel injectors .
EVEN COILS Fuse
15A
Even Ignition Coils and Even Fuel Injectors.
I would tell you to disconnect the fuel injectors an install a new fuse to see it blows then , if not shorted injector . If still blows then disconnect all the even coils an install a new fuse , if it doesn't blow then hook up coils one at a time till it blows ! Shorted coil same for the injectors . If the fuse still blows with all the coils an injectors disconnected , there is a short in the main B+ circuit for those components .
Could
Aug 06, 2016 | Cars & Trucks
1996 jeep cherokee mil code 36
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
which engine, why not post engine your fixing.??????
chapter emissions...... cht.25
see that? then go to 36 code
page 3.
oxy 1/2 heater relay problem.
then page 19 explains the tests.
1/2 means the down stream 02
and the PCM tests the relay.
and fails.
so a fuse is blown or the relay is bad. is my guess.
fuse 10 or 17?
on car i dont guess, test the relay in place.
the Fsm does not tell you , how this is checked.
does the PCM monitor the coil pin, or the output pin of the relay.
wiring page 135 (pdf page) shows the wiring
my guess is the PCM watches the relay coil, and if not 12vdc
disabled. the coil is open or fuse blow, or as is true ,endlessly
wires bad, or bad connectors.
Aug 08, 2014 | Jeep Cherokee Cars & Trucks
Efi fuse blows when car strts wher is the efi located
NO YEAR stated (old post)
there is no EFI fuse. sorry,
the ECU has 3 fuses.
FI, Dome, and IG-coil
all 3 run the ECU.
i do know what you ment.
but knowing the correct name makes reading the FSM better.
my guess 2 is you lost the fuse box cover and cant read the names.
guessing year at 91 -95
http://www.fixkick.com/power-elect/fusepanel-left-knee1w.jpg
the ECU fuse blows page. is here
http://www.fixkick.com/power-elect/blows-fuse.html
top reasons.
ECU bad CAPS
shorting fuel pump (they pull 4amps normal) if 10amps or
more they blow the fuse and or causes the ECU to click relays
like mad.
Dec 22, 2013 | Geo Tracker Cars & Trucks
My 89 civic lx keeps blowing the battery fuse everytime I connect the battery
My first guess would be a short inside the alternator, so if you have replaced it, look for a shorted wire in the harness.
Disconnect the wires from the alternator and everything connected to the battery, then connect one at a time until the fuse blows.
Could be a problem with the starter solenoid too.
Jul 03, 2012 | 1989 Honda Civic
Keeps burning fuse out. the bike will not roll over have replaced the battery twice and will run and then die??
if I had to guess, the burning of fuses and bad battery issue is likely due to a bad coil in the charging circuit. if the coil is partially shorted, it'll overcharge the battery and/or blow the fuse (possible before or after damaging the battery).
check the impedance of the charge coil, and if you can get a hold of a backup for the charging circuitry (electronics, not the coil), replace it temporarily to see if that fixes the issue.
Mar 23, 2011 | 2005 Suzuki Boulevard M50
2000 harley keeps blowing ignition fuse and hasn't got wet run fine for 1 hour seat and wouldn't start put in a new fuse turn the ignition on and pop help
Check the chrome cover over the coil. I've seen them get loose and fall down on the coil shorting the power lead to the coil. The problem could be anywhere and this is just a guess. I've seen this before.
Good luck
Steve
Nov 01, 2010 | 2005 Harley Davidson FXSTB - FXSTBI Night...
Starter relay fuse blowing in a 1995 Ford Explorer
A SHORT IN NEUTRAL SWITCH OR DEFECTIVE STARTER WILL CAUSE FUSE BLOWING.
Oct 06, 2009 | 1995 Ford Explorer
Clio 182 2005 Coil? Fuse blowing regular (30a blade under bonnet)
How do u know that the engine is not firing? What about the housing cover where the fuse is being housed? There is ususally a schematic diagram for the fuses there or, at the back of it. There u will know the type of fuse that is always being blown. If any queries, u should probably check an auto electrician
Jan 07, 2009 | 2005 Renault 181
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Feb 23, 2007 | Hifonics BXI 1606D Car Audio Amplifier
Samsung TXN3298HF 32" TV Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
