Question about Car Audio & Video
WIRING DIAGRAM FOR ALPINE CVA -1000E
I have a Alpine CVA-1000E stereo and having problems powering up.All fuses are o/k and I have 12v power at the rear of the unit.Could you please supply me or tell me where I could get a wiring diagram for this unit.I have the owner's manual but there is nothing in that.
Kind Regards,
John
  • 11 Answers
SOURCE: A/V AND Power wiring diagram
hi on what you have just told us go and get the same cables that you were using in the old car coz this wires are the ones ment for the screen i mean right holms,right jack pins for it . good luck .
Posted on May 11, 2007
SOURCE: instaling alpine car/cd stereo cda 9807
how do i install my alpine cda 9884 ...on a 92 caddi
Posted on Nov 18, 2008
  • 14 Answers
SOURCE: alpine cva 1004 r head unit
make sure the handbrake wire is attached to a gd ground or it won,t allow you into the menu because it thinks its unsafe while the ignition is turned on !
its a yellow/blue striped wire that needs to be earthed !
Posted on Nov 19, 2008
  • 6 Answers
SOURCE: alpine cva-1003 car vidio player with dvd vidio changer and navigation.
Go to alpine .com and scroll to the bottom of the screen to support.Click on support then type in
cva-1003 and there you will get the manual for free.................................................!
Posted on Nov 26, 2008
SOURCE: vauxhall zafira towbar wiring diagram.
what make of towbar wiring kit was fitted ? You can get a Whitter grey (S) fitting kit but this connects to their own black (N) wiring kit I would think any supplier of the N wiring should be able to supply a S kit.
JB
Posted on Mar 13, 2009
I need help hooking up a rca converter box in a Lincoln town car carter with the alpine stereo system
Is the converter powered or passive? Each RCA (red or white) connection represents a + and - speaker wire for one speaker or channel. So assuming you already have the amplifier you'll cut the speaker wire coming from the head unit. From the head unit speaker wires will attach to the input or hi-level connection on the converter. The other half of the wiring goes to the speakers in the doors. Those will go to the amplifier which is or should be fed by the RCA's on the hi-level converter box.
Passive coverters don't require 12v power but active ones will need 12v input from a remote signal such as from ignition circuit or a power antenna to turn the unit off and on so your battery isn't drained with the car off.
Feb 28, 2017 | Alpine Car Audio & Video
How can i test my alpine cva-1005 head unit
You can bench test it by hooking up powers and ground to a battery (12 volt) and use a speaker to one set of speaker wires at a time. Even a 12 volt cordless drill battery will work. Should only take a few minutes. You just won't get reception to radio stations without an antennae.
Feb 18, 2010 | Alpine CVA-1005 Car Video Player
Trying to re install stereo and need the wiring colors and diagram
Sony, Alpine, Pioneer (1999 and up), Eclipse, Kenwood, JVC, etc up_arrow.gif P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Jul 08, 2009 | Pioneer KEH-P2800 Cassette Player
Video image wont show. safety warning.
grounding the brake wire will allow you to view video while driving but may require an sequence (on off on or whatever it calls for) to turn on video playback so i suggest grounding the wire and putting a small toggle switch on the wire. i have done this in many cars during my strent as a professional car audio installer
May 23, 2009 | Alpine Car Audio & Video
Alpine cva-1004 no audio video ok
Many aftermarket car stereo has to output trigger wires, one antenna and one amplifier. Antenna trigger only works in radio mode for the power antenna to operate. Amplifier wire operates in any mode the stereo is in. Check to make sure you hooked up the correct blue wire to your amplifer.
Bob
Nov 13, 2008 | Car Audio & Video
Don't keep memeory
follow this code:
Black-----------ground
Red------------12V Switched (ignition)
Yellow---------12V (constant)
Blue------------power antenna
Blue/white----Amp turn on
Orange--------dimmer
White----------Left front+
White/blk-----Left Front -
Gray-----------Right Front+
Gray/blk------Right front-
Green---------Left rear+
Green/blk----Left rear-
Purple---------Right rear+
Purple/blk----Right rear -
In a grand-am the radios yellow goes to the cars orange and the radios red goes to the cars yellow.
1998 Pontiac Grand Am Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
May 13, 2008 | Alpine CDE-9843 CD Player
Cva 1004 dvd
move all power lines away from unit and connect all grounds to same spot
Mar 17, 2008 | Alpine CVA-1004 Car DVD Player
Help
Depending on the vehicles wiring itself, Alpine uses the below color coding for its wiring:
yellow – constant +12v such as the positive battery terminal
red – switched 12v such as the accessory terminal of the IGN switch
black – ground which could be the chassis/body ground of the vehicle or the negative terminal of the battery
blue/white - remote trigger for add-ons such as a power amplifier
blue – will activate a power antenna (if present)
white and white/black - front left speaker + & -
grey and grey/black - front right speaker + & -
green and green/black - rear left speaker + & -
purple and purple/black - rear right speaker + & -
orange/white - reverse wire
white/pink - monitor control lead
pink/black - audio interrupt from mobile/cell phones
yellow/blue - parking brake
yellow/black - foot brake
To bypass, the yellow/blue must be triggered negative/grounded. Alternately, it may be easier to use an adapter such as a Peripheral PTR7 (http://peripheralelectronics.com/). In some regions, it is not allowed to operate this unit while vehicle is in motion.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck, kind regards and drive safe.
Jan 10, 2008 | Alpine CVA-1003 Car Video Player
Alpine cva 1005 picutre problems?
Make sure the VGA cable that goes to the brain is fully seated at both the display and the brain box. It's what controls the video signals.
Dec 06, 2007 | Alpine CVA-1005 Car Video Player
Alpine CVA-1004
lol i had the exact problem that you are having with my alpine. The solution is taking the blue cord that was inside the vehicle (forgot what cord it was) and actually connecting it with the other blue cord thats different makes the factory amp read the cd player and ta-da it works. crazy isn't it
Sep 17, 2006 | Alpine CVA-1004 Car DVD Player
Car Audio & Video Logo
786 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
