Question about HP OfficeJet 6110 All-In-One InkJet Printer
Color Copies Am I able to copy black print and make it red, if so, how do I do this? I am using the office jet 6100 series Pam
    Problem Solver:
  • 18 Answers
Please scan it in and then change the color using any editing software
Posted on Mar 18, 2008
I only use black in for my printed copies. Is it necessary to have ink in the color cartridge in order to print
Hello, Diane -
I would need to know the make and model of your printer to provide you with a definitive answer.
That being said, most black & white & color printers made and sold these days use the color inks along with the black ink to print black and gray tones. So . . .
Yes, you will need ink in the color cartridges as well as the black in to print.
Best wishes.
Jun 14, 2018 | The Office Equipment & Supplies
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
How many copies will the Lexmark Z600 print out?
Specs say 10PPM black and 8PPM color in quick mode.
If you use higher resolution it will be reduced accordingly.
Refer to:
Z600 Series Specs
That is for a Z601, but the 600 should be the same.
Thanks for using Fixya.
Jan 01, 2010 | Lexmark Z600 InkJet Printer
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP 7410 will not print in color. Black
my hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
Jul 13, 2009 | HP Office Equipment & Supplies
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printer will not Print Black Ink copies
try to clean and allign the catridges from the front panel menu of the printer..
regards,  raj_p5983
Jan 11, 2009 | HP Photosmart C5280 Printer
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
