Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges.
To check ink levels, follow the steps below.
Press the Setup button.
Press the down arrow button until Tools is highlighted.
Press OK .
The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
Open the printer Toolbox :
- Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
Click Settings .
Click Print Settings .
Click Printer Toolbox .
2. On the
Device Services tab, click
Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
Open the All-in-One Toolbox :
Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
Click Settings .
On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
