Question about Samsung 793S 17" CRT Monitor
Samsung793s led blinking no disply
Unplug status ok but plug the vga cable monitor led blinking no disply
  • 2 more comments
  • SPEEDSAMS Feb 18, 2008
    iam connect to tv tunner
  • tonysam1011 Jul 03, 2008
    Even i have the same problem i tired different CPU. I tried with graphic card, it got detected but when i connect to onboard display the Led blinks with no display. Can someone please help.
  • boybawang Aug 19, 2008
    I have thesame problem. The screen is Blank and the Green Led Blinking. The unplug image status is OK.
    But my CPU is working fine because it continues to boot despite the screen is Blank. Infact I can hear the "Windows Welcome Sound."
    Please help me I'm desperate! :( :(
  • samxxman Apr 12, 2009
    With samsung syncmaster 753 . Without signal cable plugged in, it give good " no signal " display. As soon i connenct on good PC, green led blinks and no display.
    Cable is oke.Pc is oke.
    Sami
In the place of circuit where the vga connection is connected, may be six diode is still there. one or more are shot, change it, ifr the new one is also shot pls change the controll IC. Thanks
Posted on Jun 17, 2009
Its only an idea!
Crt monitors needed to heat up the vacuum tube. Before opening, so i guess you just need to wait for it to heat up. Then try to turn it off. then turn it on again.
Posted on Oct 13, 2008
  • 983 Answers
The vga card is not connected properly i think in cpu .. just reconnect it... and then have a try..... it should work...
Posted on Feb 13, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Aug 19, 2008
    may be there is some problem in the VGA cable (which you are connecting from the TV tuner) just have a check with that if needed replace the cable ....
Whats the problem with no picture on the monitor but the cpu is working
Can you observe any LED lights on the monitor panel when you try to turn it on. If no then check your power cables. If you can see the LED lights but screen does not show try to unplug the VGA/HDMI cable and clean it by blowing air through the plug and then reconnect it. Also try to turn on the monitor without connecting it to the monitor as this will verify if the monitor is OK because if it is it should display a message to check the input signal or no input signal is detected. If it does and you are still not having a display then the problem is probably in your CPU and more specifically in the VGA card.
Sep 23, 2013 | Samsung Computers & Internet
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Power on power led blinking
Hello.
The LED blinking light usually means that the attached PC is not powered on or the VGA connector (end of cable connected from the monitor to the PC) on the monitor, the cable or the VGA port on the PC is faulty.
Try your monitor on another computer. If it works, there is a problem with your PC. If it doesn't work, the VGA connector, the monitor's VGA cable or the monitor itself, is faulty.
Hope this helps.
Jan 23, 2011 | LG Flatron L1710S 17" LCD Monitor
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
We have an almost three year old HP pavilion but suddenly the monitor stopped displaying the information from the computer. We think it's a graphic card issue but the BX where we purchased it didn't want...
First Remove the VGA cable from your pc backside and turn on the monitor alone and you should find some message that VGA cable unplugged or VGA not found like that... If it comes then the monitor is ok...
Then power on the pc and you should find out the harddrive's red led will blinking and you will get also one beep then it will ok,
if it is really problem with graphics card or display issue, you should get some beep codes continuously (2 or 3 beep sounds)
Thanks...
Sep 21, 2010 | HP Computers & Internet
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Iam a monitor tecnician
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Samsung 793S 17" CRT Monitor
Samsung 793S 17" CRT Monitor Logo
148 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
