Question about Epson Perfection 1670 Flatbed Scanner
Dirty platen The glass platen has a film on the underside where I cannot clean unless I disassemble the scanner and that looks problematic.  If there is an easy way to get at the other side I would like to know.  Otherwise a professional clean costing about as much as a new one most likely.
  • Anonymous Feb 23, 2008
    dirty glass platen ... need to take apart scanner and clean. HOW?
I had the same issue. This is my second unit - I returned the first one when I noticed the problem. The new unit had the same issue out of the box. I disassembled it and cleaned the glass. The film reappeared almost immediately. Perhaps these units run hot and produce minute quantities of smoke (?). This problem does not seem to affect the scan quality as I scanned thousands of pics with it, many of which appeared in a book.
I used the scanner for four years and now it died. Was well worth the money.
Posted on Feb 27, 2008
My suggested solution was to become an Elite Expert and to consult myself.
Posted on Feb 13, 2008
How to clean the underside of the scanner glass on an HP4400C flatbed scanner.
This is acutally easier than it looks. I just had the same problem with a cloudy film starting to form underneath the glass on my older HP 4400C scanner.
First completely remove the hinged top lid by lifting straight up on both long ends of the lid - notice the 2 hinges on the back end of the lid will come straight up and out of the body of the scanner, still attached to the lid.
Next look down inside the 2 hinge holes (on the main body of the scanner where the lid hinges just came out of) and you will see a screw in each hole. Remove both screws using a phillips screwdriver. This will allow the rear end of the scanner to come apart enough so you can now lift it up a few inches to separate it and get your hand inside there to clean the underside of the glass with a soft cloth - BUT JUST REMEMBER THE FRONT END OF THE SCANNER WILL STILL BE CONNECTED, so don't pull it too far apart because it could snap and break something that is still holding the front end together. (I could not figure out how to separate the front end piece, and then I realized I didn't have to).
So on the rear end of the scanner, now carefully pull the light upper colored plastic apart from the lower dark plastic just enough so you can get your hand inside the compartment and use a soft cloth to clean the underside of the glass. I just used a small piece of an old cotton t-shirt with a couple little dabs of water on it and then just kept rubbing the dirty areas on the underside of the glass over and over until all the dust film/streaks disappeared and the glass was once again clean and all clear.
Then gently lower the glass back down and line up the plastic pieces together on the rear end and put the 2 screws back in the hinge holes, and then reinsert the hinges in their slots and lower the lid back on top of the scanner glass and it is ready to go again !!
Hope this works for you like it did for me.
Nov 19, 2010 | HP Scanjet 4400c Flatbed Scanner
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Adjustment for light copies on a xerox m20i
You will need to do a couple of things, 1 remove, disassemble the scanner and thoroughly clean it, and while you have the scanner out, remove and clean the laser.
The toner cartridge may also be defective. that metering blade in that cartridge fails and causes light images also.
If you need instructions on how to remove and clean the scanner and laser let me know, I will type them out to you.
Not hard, just time consuming.
If you print out a report how does that look? If prints look fine and just the copies are light, then the mirrors in the scanner head a re probably fogged up. All the plastic in that scanner causes that same film on your scanner optics as you develop on your car windshield. Same process.
Jan 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon 9900f scanner glass removal
I would not worry about the underside of the glass unless you are having problems. The focal length of the ccd that captures the image is very specific and probably will not pick up anything under the glass. It is normal for the underside to look foggy but it will not hurt anything.
Jul 25, 2008 | Canon CanoScan 9900F Flatbed Scanner
White spots on scanned photos
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Apr 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How to clean underside of platen?
The underside of the scanner glass can only be reached by a a canon service tech. The compartment is supposed to be sealed and dust-free, so if it has gotten dirty, you should send the unit back to Canon for servicing.
Feb 07, 2008 | Canon imageCLASS D320 All-In-One Laser...
Inside platen glass needs cleaning
http://www.nifty-stuff.com/forum/viewtopic.php?pid=32066 use this link for disassembly it gets the printer and scanner apart but does not show how to disassemble the scanner.
Nov 27, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Epson Perfection 1670 Flatbed Scanner Logo
1,259 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
