Question about HP LaserJet 4000t Printer
IP Address How do you change the IP address and also change the Config By: From DHCP to Static
  • 32 Answers
Tip
Wireless printer goes offline
Let's set a static IP address for the printer:<br /><br />- Print a Network Config Page from the front of the printer. Note the printer's IP address.<br />- Type that IP address into a browser to reveal the printer's internal settings.<br />- Choose the Networking tab, then Wireless along the left side, then the IPv4 tab.<br />- On this screen you want to set a Manual IP. You need to set an IP address outside the range that the router automatically sets (called the DHCP range). You can change the DHCP range of the router using its internal settings page.<br />- Use 255.255.255.0 for the subnet (unless you know it is different, if so, use that)<br />- Enter your router's IP (on the Network Config Page) for the gateway and first DNS. Leave the second one blank.<br />- Click 'Apply'.<br /><br />Now, shut down the router and printer, start the router, wait, then start the printer.<br /><br />After this you may need to redo 'Add a Printer' using the new IP address.
on Apr 02, 2011 | Office Equipment & Supplies
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
Changing of I P Address
You can use any router. All routers these days comes with a DHCP server feature built-in. However, you have to ensure your desktop is set to receive ip address and dns dynamically from the DHCP server.
However, if you wish to have the same ip address always but dynamically assigned by the DHCP server and not a static ip addres, you need to go for a router that provides static dhcp ip address.
You may check Linksys, where you could find one of their model which has this Static DHCP feature.
I hope this helps
Apr 02, 2009 | U.S. Robotics (9107) Router (USR9107A)
Static config
DHCP is superior to Static IP in every conceivable way. It is not any slower. However, when you FIRST connect to a dynamic ip router, your computer and the router have to handshake a bit, which takes a few seconds.
After that, they are at the identical speed. DHCP shields you from all sorts of trouble like colliding IP addresses, DNS server, subnet masks and gateways. It is way better and more reliable to go with DHCP.
Static ip is only useful if you *need* static ip, e.g. if you want to host a server on your router and you need the computer's dns server to stay the same.
That said, if you still want to use a static ip, here's how:
Simply disable the DHCP server in the router's settings. Also, go into the router's "status" page and take note of the DNS ADDRESS(S). You will need this later.
(Please note, if you disable the dhcp server, the only way to get back into your router and re-enable it is to use static ip on the computer, or to hard reset the router)
Then, you configure each computer connected to the router to use a static IP as opposed to obtaining it automatically. To do this in windows XP:
Go to start->control panel->network connections
Right click on Local Area Connection and go to Properties
Select "Internet Protocol (TCP/IP)" from the listbox
Click Properties
In the general tab, tick the radio box "Use the following IP address"
Type in the ip adderss you want (e.g. 192.168.0.105)
Type in 255.255.255.0 as the subnet mask
Leave the default gateway blank
Type the ip address of the DNS server you took note of earlier into the "Preferred DNS" section at the bottom of the form.
Click ok and ok and ok until you're out of all the boxes. Your IP is now static, and cross your fingers. If you did everything correct, it will work. If not, check your settings.
Feb 04, 2008 | Edimax BR-6104K Router (br6104k)
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
HP LaserJet 4000t Printer Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
