Question about Canon MultiPASS MP360 All-In-One InkJet Printer
MP 360 won't print
I was having trouble printing black , appeared heads were clogged. Did a couple of cleanings using first alcohol then windex. Black quit altogether but could get a color print OK. Got a new print head and now cannot print either black or color. Even after head cleanings. There is ink in the print head well but not obvious on the paper side of the print head????
  • 1 more comment
  • David Forehand Feb 14, 2009
    I have the same problem with a a recertified mp61. Called canon tech, went through 5 normal cleans, 3 deap cleans, still nothing printed. You can tell ink was being sucked in but the bottom of the head where ink comes out looks clean. Was rushed ordered a new print head. Went through the same cleaning steps, still nothing. I will have to call support again. There seems to be a serious flaw in some of these printers.
    same problem with a mp610, called canon tech, went though 5 normal nozzle cleanins, 3 deep cleanings, still nothing printed. Was sent a new print head. Went through same cleanings, still nothing printed. Ink appears to be sucked in, but bottom of print head appears clean.I will have to call canon tech again.
  • Anonymous Mar 25, 2014
    COLORED HEADS NOT PRINTING ROUTINE CLEANING DONE
The Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
I have a brother all in one MFC 685 CW &having problems printing
Not sure where you found the recommendation to use Windex on your print heads but chemicals should be avoided. It sounds like you have damaged so of the head elements and now they are leaking. There are specialized fluids for cleaning print heads or plain old water will dissolve ink as well. Too late for you however if the heads have been damaged they will need to be replaced.
Oct 06, 2016 | Brother MFC-685cw InkJet Printer
My Canon won't clean its print heads
Have you tried power cycling the printer?
Feb 17, 2008 | Canon i860 InkJet Photo Printer
I have a Brother MFC-6490CW that my husband purchased for me somewhere between one and two years ago. I just recently decided to use it, and the black ink would not print. I thought the original...
Power purge the machine:
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Feb 25, 2011 | Brother MFC 6490CW InkJet Printer
Hi Experts, I've have clog print head for the black color. Did a nozzle check black doesnt print, did several head cleaning still did not help. Now using cleaning solution to solve the print...
Is your colour ink come out when you print nozzle? If yes, your printer head is alive. In this setuation you should push some alcohole cleaner through plustic seringe several time. If no, there is a trouble in your printer's main board. replace the main board or repair it by a repair man.
Thank you.
Dec 28, 2010 | Epson STYLUS R230 InkJet Photo Printer
I have an Epson Workforce 600 printer that won't print black ink. I have replace all the cartriges with new and still no black ink. I've done nozzle clean several times. Only a very faint line on test...
You may have to clean your HEADS. I found this on the Web. Hopefully this will help. Pls rate me.
Good Luck
Found this on the Web:
http://www.fixyourownprinter.com/forums/inkjet/14116
Epson Stylus Head Cleaning Solution Plus
Re: Epson printer problem
You will want to press the button that you use to change the ink cartridge (the 3rd button). Once the carriage is in the "cartridge change position" you can unplug the printer. Then you are ready to flush out the heads. Click here for cleaning instructions http://www.wesesweb.web1000.com/printhead.html
The instructions are fairly easy to follow. If you need the head cleaning solution click here .http://www.fixyourownprinter.com/kea0.html
Repairs: All Epson Stylus printers (except for the C64-C86, CX4600-CX6400 series) which don't print, or print choppy in black or color. For the other printers, as well as Canon BJCs, use the other repair kit.
Description:
  • This is the same chemical used by Epson in their service department
  • Easy to use, no disassembly required
  • Gently dissolves even the most stubborn clogs and restores output to dried out print nozzles and clogged printheads
  • In our testing on an Epson 600 that sat unused for several months, it 100% restored a head that had no output, with one application (Individual results may vary)
Note: This is not alcohol or Windex; it is an ink-specific solvent that has proven to be safe and effective for use on Epson printheads. Do not use alcohol or Windex, they will very likely ruin your printer.
Kit Includes:
  • 1 oz bottle Epson Stylus Head Cleaning Solution (enough to fix several printers)
  • 1 syringe applicator for dispensing solution
  • Simple directions for use
Price: $9.99 order form on link below
http://www.fixyourownprinter.com/kits/Epson/K89
Feb 25, 2010 | Epson WorkForce 600 All-In-One InkJet...
My printer Canon MP760 does not print black.
Your black ink must be empty replace with a new one and print.
Sep 20, 2009 | Office Equipment & Supplies
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
PIXMA MP780 - not printing black chararcters
All the people in this forum with a Canon ink printer not printing black, especially if you tried replacing the print head and still have the same problem.
Your purge unit/capping assembly is most likely clogged. This can be caused by using crappy ink cartridges and by not using the printer for exptemely long periods of time.
You will have to disassemble the printer. First open the lid so the print head moves into the centre of travel. Unplug the power cord. Remove the upper case (can be hard to do, usually they're snap-together).
Remove one screw on either side of the print engine and remove the engine from the lower case. Unplug the cables that go from the main board to the purge unit (the large black assembly covered with old ink, located on the right side of the printer where the head usually would stop after you've finished using the printer and shut it off).
Now you have to remove that black purge unit from the right side of the engine. Usually there are two screws holding it in place.
Give the unit a bath, carefully removing old ink from everything so the unit looks like new. (be sure to remove the one motor first or you will ruin the motor). Check the bottom and make sure the two small clear rubber tubes are not clogged with old ink. Clean the absorber off (the pad in the lower case) if it has ink piled into a small hill shape.
If the tubes look like they might be clogged, you'll have to find a way to clear them out. I can do it in my shop, but it's too in depth to explain.
Reassemble the printer, connect to a PC and do a few deep cleans and print out a test page. Problem solved.
Remember, if one colour is not working it's because the head is clogged. You will have to do multiple cleans to get it to work. If it still doesn't work, then either it's REALLY clogged or the purge unit is not working because it's clogged. If you buy a new print head, then the only thing left is the purge unit. Be brave and try the disassembly and cleaning, or take it to your local service shop.
We charge $45 CDN for a job like this.
Rule of thumb: If you can get it fixed at a shop for 1/2 prince of a new unit, go for it.
Jan 02, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
322 people viewed this question
old marine
old marine
