Question about Olympus DS-2 Digital Voice Recorder
DS-2 lock does not get deactivated
I have got a sign of lock . Its not recording and saying read only file . What should I do.
  • 2 more comments
  • littlems97 Feb 14, 2008
    i have the same problem. i try to unlock and it just says "read only"
    i cant unlock it
    what do i do?
  • Anonymous Feb 20, 2008
    same deal?
  • veenotph Mar 26, 2008
    Same problem. I just changed the batteries, and everything is locked. "Read only Memory" Going to Lock in the menu doesn't help.
  • Marigringota Apr 11, 2008
    I have the same problem. Ugh. Any suggestions out there? I try to record and just get the "read only memory" flashing signal.
I had the same problem with my ds-2. The solution for me was
FIRST: Copy everything off of the DS-2
SECOND: Reformat the recorder. Go to Menu > SubMenu > USB Class >reformat
Cheers,
Jay
www.gturn.com
Posted on Apr 18, 2008
  • brainds2 Mar 24, 2011
    works great now
Unlock DS-2400
If a file is locked, use the Lock command in the File menu to unlock it. If the memory card is locked, slide the switch on the edge of the card away from the contacts.
Aug 01, 2012 | Olympus DS-2 Digital Voice Recorder
Hi, All Folders are locked and if you try to record its says READ ONLY CARD? I have 1 sound file on the card which i need. It won't play on the computer system either?
The memory has been corrupted. You will need to reformat the memory from the menu in order to use that memory card again. This will erase all files.
If you need to recover the file, download a free recovery program called pc inspector smart recovery, from http://www.snapfiles.com/get/smartrecovery.html
Jun 23, 2011 | Olympus DS-2300 Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
Locked file ?
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Recorder Locked
The same problem "Read memory only". The best solution is : submenu/format/start
Good Luck
Mar 26, 2008 | Olympus DS-2 Digital Voice Recorder
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-2 Digital Voice Recorder Logo
331 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
