Question about Apple iPod nano 3rd Generation
Ipod not turning on/not recharging
Dear sir,
SUBJECT: IPOD NOT TURNING ON/NOT RECHARGING
ive recently bought this 30GBipod n its serial no is 9C7267DFV9M.AND the model no is MA446ZP/A.when i first time used the i pod it was fine,the second time i try ed to recharge it, its not switching on in any of the pc.neither is it showing da sign of da battery being charged.
PLEASE HELP.
thank you
my brand new ipod will not work it is the nano 3rd generation ive used it lots of times and this has never done this before. 3quaters of the battery was charged and i turned it off and later that night iwent to listen to it and it woulndn't turn so went to plug it into the computer and it wouldnt charge and it hasent worked since
  • 3 more comments
  • ctiffanyc Feb 25, 2008
    I placed my ipod on the charger and attached it to the computer to charge and nothing happens. it normally flashes with the red apple sign while charging. Please help with a possible solution.
  • Anonymous Jul 09, 2008
    dear sir,
  • jrsaeta Jul 31, 2008
    My ipod is not recharging the battery. If anyone has had this experience and knows what to do about it let me know.......
    Peace
    Jrsaeta@aol.com
    Peace
    Jrsaeta@aol.com
  • bondeng Aug 01, 2008
    Dear sir,
    My ipod nano third gen silver is not turning on. I've used it for a month and it was fine then. Now i dont know what to do. please help.
  • 51 Answers
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Posted on Feb 14, 2008
Thnks yr genius
Posted on May 02, 2008
MY IPOD IS STAYING DIM ALTHOUGH IT IS SET ON HIGH BRIGHTNESS. I HAVE ALREADY TRIED TURNING IT OFF AND BACK ON
is battery fully charged? if not try recharging it. Otherwise sync it to iTunes and use iTunes help. sorry i'm not the best at iPods
PS. try upgrading/reinstalling drivers and OS onto iPod
Jan 24, 2010 | Apple iPod touch
My ipod touch wont switch on or connect to itunes it turned on yesterday and this morning but now it wont
You should try recharging it, the battries do not last long on the ipod touch.
Dec 27, 2009 | Apple iPod touch
JBL on stage micro will not charge my ipod any more. It plays songs fine from the ipod but for some reason is not charging it. Any suggestions?
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
Jun 14, 2009 | JBL On Stage Micro Portable Speaker Dock...
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Unable to recharge
Make sure the hold/lock is not engaged
Jan 06, 2009 | Philips GOGEAR SA6045 MP3 Player
Recharging
Had the same problem with mine. Strip your ipod and you'll find that the left hand end of the battery has been rubbing against the mounting screw for the hold button and the positive track is exposed causing it to short out the battery. Placing a piece of plastic between the battery and the mounting screw sorts out the problem. My ipod charged and the battery still works fine. It seems to be a common problem with this model. If you want more details email me at martin.gary13@yahoo.com
Sep 16, 2008 | Apple iPod classic MP3 Player
Usb recharging does not work
I have seen this many times. Your battery is most likely depleted to the point that it is incapable of sending a signal to the computer. You will more than likely need to have you battery replaced. You can jump start your iPod with a wall charger, but you lost yours. A simple charger can be bought off of eBay for less than ten dollars. If you get a wall charger and nothing happens, your iPod is dead but it sounds like a battery issue.
Aug 28, 2008 | Apple iPod MA446LL/A MP3 Player
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Jan 12, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod recharging
how do i download Movies & photos to my apple ipod
Dec 26, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 3rd Generation Logo
1,439 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
