Question about Marantz DV7600 Progressive Scan Universal DVD Player
CPPM error code
I recently went into the menu system to open zone my DV7600.
It worked but now when the player is turned on it reads "CPPM ERR".
The player works but it's clearly not meant to display that message.
I have tried holding the stop button but it won't reset like the maunal says.
Anyone had this?
Thanks
  • Brownz_1 Oct 05, 2008
    I have similar problem, when I turn on my Marantz DV7600 I get a message "EEP ERR". I recently was "treated" by my cousin to him unlocking it so that it will play all regions, I live in Europe and it was a Region 1 DVD player.
    I would be able to put up with this however whilst playing a song, usually the 2nd or 3rd that I am playing, it seems to crash, for want of a better description. The play speed goes slow then fast and it seems to die a death!
    I have tried to contact Marantz on numerous occassions to find out what the message means and best case, that they give me the correct coding to get it back to Region 1 as there wasnt a problem!!
    If anyone knows what the problem is or a way for me to get it back to region 1, when it was working perfectly, please let me know
  • MetalZeke Feb 04, 2009
    Hi 993man,
    I got the same problem. It is now one year later, and I was wondering if you have a solution? Can you please tell me?
    Greetz from the Netherlands,
    Zeke
2 Suggested Answers
SOURCE: What does this Error Message mean?
hello AuburnCE, After 4 years of joy my Marantz SR8200 receiver also shows this message from time to time - after 1h of operation or so. Then it is hanging (like a PC ;o). Taking it of from the electricity network for a moment resolves the problem until the next POW 05 hang usually a fiew days later. I brought the receiver to an authorized Marantz maintenance and repair center twice now and they were not able to reproduce the error. They said this has directly or indirectly to do with the power supply unit. They also called marantz. For me it appears that this is not an internal receiver problem IN MY CASE. I think I there might be a relationship to zapping on my Topfield SAT receiver via power supply network as the connection is optical. Or my dimmerunit for the light. Unfortunately I do not have a separate electric circuit for Audio/Video and all other electrical devices. and dimmer units are well known to cause problems in the power supply chain - e.g. like noise in your audio package. Please note: the experts told me: Check POW 05 can have other (receiver internal) causes also. Above is just my suspicion 8as a non-expert) for my case . Regards, Fred
Posted on Sep 11, 2007
ESP-6TM Sprinkler System - Everything on the display is correct. Then the unit reads "Err" and will not activate. Tried reprogramming with no luck. What is the problem?
When it gives the "ERR" code, usually it flashes the zone number after that. This will only do this when the system is set to "ON". Sometimes, error codes pop up for no apparent reason, with no fault in the system, and attempting to clear the alarm is the first step in troubleshooting the system. When turned to "ON", and the "ERR" alarm is displayed, hit the ENTER button. This should clear the alarm for a single zone. If another ERR is displayed, clear it also by pressing ENTER. Turn the system back to OFF, wait 10 seconds, then turn to ON. If no ERR codes are displayed, the system should cycle properly on next use. If ERR odes are still displayed, make another attempt to clear them, and re-check. If they cannot be cleared, trace down circuits to the valve boxes for each zone, and make sure that all wiring connections are good, dry, and tight. Solenoid valves can be removed with the water shut off, and tested at the control box by wiring them into the terminal strip site for a known good circuit, and then operating that circuit. If the valve is good, you'll see and hear the diaphragm move.
Best regards, --W/D--
Jun 02, 2011 | Garden
I need to hack the region of the Sony DVD SR500H
Hi there
Follow these steps and your dvd will be able to play discs from any region.
*With the player in stand-by mode (take out any discs and leave it alone for several minutes) press on the remote, in this order: TOP MENU, CLEAR, POWER.
*A menu will appear with several options. Choose Option 2 and then Option 4.
*Type 12450, press enter, then type 00000.
  • Step 4 After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvIMQI5i
    *After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
    Thank you for visiting
  • Step 2 A menu will appear with several options. Choose Option 2 and then Option 4.
  • Step 3 Type 12450, press enter, then type 00000.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvI1JPoD
    Jul 27, 2010 | Televison & Video
    Walgreens HD303 Blood Pressure Monitor error 3
    Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
    Error Description Potential cause and remedy
    «Err 3» No pressure in the cuff
    An adequate pressure cannot be generated in the cuff. A leak
    may have occurred. Replace the batteries if necessary. Repeat the
    measurement.
    Error Codes
    Err 0 No pulse is detected
    Err 1 Inflation rate is too low
    Err 2 Systolic reading unattainable
    Err 3 Cuff pressure is too high
    Err 4 Diastolic pressure is outside of operation range
    Err 5 Cuff deflated too fast
    Err 6 Cuff deflated too slow
    Err 7 Systolic pressure is outside of operation range
    Err 8 Overall pressure is outside of operation range
    Err 9 Cuff is unable to inflate to the necessary pressure level
    Error No. Possible cause(s)
    Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
    Err 2 The arm was moved during the measurement.
    Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
    Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
    Audio/CD Player
    dear friend- the error code means the lazer is not reading your cd,if it is a pirate cd it might be the problem,or the lens must be cleaned.
    Apr 17, 2009 | Hyundai Motor 2004 Sonata
    After Changing my Battery my CD Player has a "Code "Flashes Now Err Fashes
    When you bought the car your dealer must have given you that code or you can call them and let them know your registeration details they will give u the code for free all you have to do is to give them your details.
    Good Luck !!!!!!!!!!!!!!!!!!!
    Sep 04, 2008 | 2004 Mazda 3
    Cd player takes cd the releases with ERR showing on the display
    open cd player.clean lens with cotten.your problem will be solved forever.had same problem.
    Jul 15, 2008 | 2001 Nissan Sentra
    Denon udcm m7 cd player often reads ERR on play and eject
    Try cleaning the laser first. Take care, because it is delicate.
    Some instructions of how to clean a CD laser:
    http://www.wikihow.com/Clean-a-CD-Player
    If the cleaning does not fix the fault, it is possible that the laser is weak, or there are some problems in the electronics in the CD player. This is not something you will be able to service yourself, unless you are properly trained, have experience, and have the proper setup to perform CD player servicing.
    In most cases these CD players are not cost effective to service. You can contact the orignal manufacture for details or any recomendations.
    Jerry G.
    Apr 29, 2008 | Bose & Wave& Music System
    Error
    Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
    Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
    Televison & Video Logo
    83 people viewed this question
    Top Marantz Televison & Video Experts
    Marvin
    Marvin
     Grubhead
    Grubhead
    Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
