Question about RCA F36674ET 36" TV
RCA F3667ET Flyback Transformer Failure (again!)
"TV Turns Itself Off.
What would I have to do to fix this problem?
I was watching tv the other night and it turned it self off. when i tries to turn it back on, it cliked on then click right back of three times and then stayed off. I unpluged and tried it again with the same results. Help!!!!"
I have this exact problem. However, trying to turn it on enough times, now all I hear is a chirping that is indicitive of the power circuitry, so I'm guessing FBT failure. I inherited the TV when it had a similar flyback problem and was also chirping. I swapped out the flyback and the suggested resistors and caps (R14704, C14710, and a few others) as well as the horizontal output transistor. TV worked great for about 5-6 months. What could have caused this new FBT to fail? Is there some greater problem I might have that will cause a new FBT to fail again? I'm hesitant to invest in the repair if it's going to just happen again.
  • 934 Answers
I'm going to ignore the last paragraph of this posting - it's so cluttered that I was seriously considering not answering at all...
Whoever it is installed a HOT and half of a flyback kit and now finds themselves wondering why... duh.....
This unit is a CTC197 chassis. The MOST common failure on this unit is the FBT and HOT and if either fails test the other rigorously.. The FBT is p/n# 237506 and RCA special notes indicate to also replace C14710 & R14704. In fact if you order the FBT factory direct they will also send you the cap and resistor without requesting it..
It is not uncommon to also find ring-cracks on the board through-out the unit. Especially on and near Ic components within any given circuit like the vertical, regulator, audio etc. Always check these areas to avoid further problems or failures.
If you have isolated the problem as a HOT failure and FBT rings good strongly suspect the regulator U14701, p/n# 236646. You should easily be able to determine its failure by measuring pin 6 for 12v and pin 7 for 5v.. If either missing or even slightly low replace the regulator. Also check Cr14402, Q14802.
Bill
Posted on Feb 13, 2008
My RCA tv turned off in the middle of watching it and now it wont turn back on.red light comes on and tv makes clicking sound but no picture or sound.sounds like it turns off again.
Sounds like the Horizonal Output Transistor Shorted, Also on many RCA sets the Flyback Transformer is bad to go and short the HO Transistor
Oct 09, 2010 | RCA Televison & Video
Sony TV turns itself off after 5 second. The timer light blinks 7 times. It fixed itself for 2 days and then broke again
U know how to solders?Resolders the FBT,the flyback transformer.It a big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Jan 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv keeps cutting of soon as i turn it on what wrong wit it?
You are in shutdown protect mode, it may be due to a bad flyback transformer and horizontal output transistor, replace both if one is found bad. RCA is nortorious for flyback High Voltage transformer failure.
Dec 21, 2009 | RCA 32F531T 32" TV
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
TV turns on, then immediately off again
The flyback transformer are damaged.
May 18, 2008 | RCA TruFlat 27F520T 27" TV
Possible bad flyback transformer = RCA part # 257805......T.
Dec 10, 2007 | RCA F32650 32" TV
TV Turns Itself Off. What would I have to do to fix this problem? I was watching tv the other night and it turned it self off. when i tries to turn it back on, it cliked on then click right back of three...
That set is a CTC197 chassis with a common problem - flyback or more commonly referred to as the FBT...
The FBT is a high voltage transformer which delivers a great deal of voltage to the crt to light the tube. The FBT is RCA p/n# 237502 and a ring test can confirm its failure. Another shortcut technicians use is to unsolder the collector of the HOT and power the set. If it powers with up and has audio you're in business, just replace the FBT and it's recommended to replace R14704 its an 82k ohm- 1/2w resistor and C14710 a .01/1kv cap as well. I believe if you order these as a kit, (ie: original RCA FBT), the two other parts are included - but ask to make sure.
You might also check for continuity across E & B of the HOT with a multi-meter while you're in there and if you get any resistance at all the HOT is shorted also... Or for simple reliability just replace it anyway.
Hope this helps!
Bill
Nov 13, 2007 | RCA F36674ET 36" TV
Rca f27442
Check for shorted base-collector junction on horizontal output transistor designator Q14401. Also coil L14401 going to base of transistor needs to be desoldered, scrape ends, resoldered. If horizontal transistor is shorted, real possible flyback transformer bad.
Dec 16, 2006 | RCA F27442 27" TV
Televison & Video Logo
421 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
