Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Replaced STK ICs but image is all distorted
I replaced the STK ICs on my convergenge board because my tv was not turning on and when I unplugged the convergence board it did turn on. After I replace the ICs the tv now turns on but the convergence is totally off and the picture is curved. The perfect focus doesn't work either.
Would I have been better off replacing the whole convergence board? Will there be other image setup issues if I replace the board?
  • luis alberto Apr 10, 2009
    el mismo problema cambie los STK y las resistensias y no me prende, pero si desconecto la placa de los STK si prende
    Champion:
  • 206 Answers
Usaly when this happens the little fuses also fry they are 5 amp and located neer the ic's and at the bottom right of each ic, also they are green and look like a restor could check and see if they are open and then check all the big resistor to see if any of those show open, other than that I will paste my standard fix for this set
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Posted on Feb 13, 2008
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Do not have full 64 point convergence control on the green crt. Most all ofrt of the picture is in convergence but the top first two lines are bowed and the middle bottom line is arced in the center....
No,the tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead.Tv convergence board must be replace the 2 STK convergence ICS and also must test all of the resistors and replaces all those dead resistors too.
Mar 02, 2011 | Philips 60PP9753 60" Rear Projection...
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
The color is distorted and the images on the screen is double.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-65WP55 65" Rear Projection...
Color is fine but in top right corner have blue and yellow distortion but the rest of the screen picture is ok
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment anywhere in the picture screen.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 09, 2010 | Hitachi 60DX10B 60" Rear Projection...
DOUBLE IMAGE
Tv have a problems known as a "Convergence Problems",it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors to be replaced.These parts must be replaced,to solved the tv convergence problems.The shop should cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Getting a 3d image
The tv have a problems known as a convergence problems,it dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 20, 2010 | Hitachi 65SWX20B 65" Rear Projection...
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
418 people viewed this question
Jerry Greenberg
Jerry Greenberg
