Question about JVC AV-56WP30 56" Rear Projection Television
Where is the horizontal transistor
Replaced the convergers/resistors. Was having trouble getting the curve out of the picture, the picture was very good, went to regular programming and suddenly the tv went black. Blue indicator light was still on. Someone suggest the horizontal transistor may be out, where is it. I could not locate it in the manual.
    Genius:
  • 1,694 Answers
Cheap convergence IC's made repair more difficult.......
read some of my convergence repair solutions.............T.
Posted on Mar 23, 2008
  • Vista Electronics Mar 23, 2008
    Horiz out not at fault.....................T.
  • 156 Answers
You can follow from fly back the B+ supply is directly connected to the horzontal out put transistor.
Posted on Feb 14, 2008
I troubled samsung tv the horizontal transistro was exceed heat
It is because the flyback is drawing to much current and it needs replace, and if it still drwing tomuch current,you could have a bad picture tube.
Apr 09, 2012 | Televison & Video
Could not set blue convergence properly after it gradually drifting off horizontally. Replaced convergence chips with repair kit from tvrepairkits.com. Tested all resistors and they test good, within 5%...
U used every components,that came with that kit?Grounding ur self.Used a low wattage soldering iron resoldering the convergence ICS again,no matter what the resistors are in torrence or not replaced all of the resistors,still have the same problems.The 2 convergence ICS got to much heat and stastic ectricity charges it it shorted and kill the 2 convergnce ICs.
Dec 19, 2010 | Hitachi 53UWX10B 53" Rear Projection...
The picture looks 3D and kind of curving in
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have pictures colors shadows or have a 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
When we try to adjust red cross, red adjustment will go side to side but not up and down. Red horizontal line is curved instead of a straight horizontal line. Blue can be adjusted up and down and don't...
Thats the classic sign of failed convergence ICs and resistors. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and the Cd with instructions.
Mar 09, 2010 | JVC AV-48WP30 48" Rear Projection...
The convergence wont align the horizontal blue is curved and 3inches away from center and the vertical blue is slightly curved
Convergence is dead.Must change 2 convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a converngence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 18, 2010 | Televison & Video
Picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
May 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Horizontal Curvature with convergence problem
DA, convergence circuit has failed, the IC`s and possibly a couple of support resistors need to be replaced, your right about it being a good set, 6 years is about average for convergence IC`s, call your local shops for a few estimates and get it fixed, it will run for a lot longer than 6 years, hope this is the advice your looking for, e-mail me if you have more questions, BMW Rider
Dec 10, 2007 | Toshiba 65H81 65" Rear Projection...
Rca ctc 169
Did you replace the STK convergence IC's yet? If not, thats your trouble, or you have a plug in the wrong place. i doubt if the yolk is bad, as that would most likly blow out the horizontal output transistor and the set would be dead. Good Luck, Please do not forget to rate this thread.
Dec 07, 2006 | RCA P46924 46" Rear Projection Television
JVC AV-56WP30 56" Rear Projection Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
