Question about Mintek DVD-1810 Portable DVD Player \
All of the sudden won't start at all
My dvd palyer mad a strange humming noise and the start up screen got all lined and now it won't start at all....w/ battery or AC???? Never had any problems, never dropped, used according to manuel?
  • tacolady2003 Mar 24, 2008
    ive only used my portable dvd player a couple of times and stored it for about 6 months now it wont even start
  • 24 Answers
Sounds like a capicator took a shot. Call the manufacture or contact their customer support. If it's under warranty, I'm sure they'll fix it no problem.
Posted on Mar 19, 2008
My kitchen aid refrigerator model kssc42qms02 making humming noises and the the temp lights are flashing
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
Apr 24, 2012 | KitchenAid Refrigerators
I have a TTM 2003 and the sound has gone bad the TV is humming. Do I need to junk this or can it be fixed ?
With the price of new ones, you are further ahead in replacing the set, cost to repair will be close if not more than a new one.
Mar 12, 2012 | Polaroid TTM-2003 Combo
Makes a humming sound between 30 and 40 mph
I suspect that one of your wheel bearing have worn out. SO to confirm please lift up one by one all the wheel and rotate. listen to any hum which corresponds to your noise. hold the wheel on either sides and check for any shake even a small one. if you detect a hum check the wheel bearings and the HUB, most cars have this assembly making the noise specially when the grease becomes dry or there had been water logging specially salty.If so change the bearings / hubs, when changing look out for any damage to the axle. I hope you get this right. Helpful? Good day.
Jul 07, 2010 | 2001 Oldsmobile Alero
Have a strange humming noise that can be heard
Hi:
Often "humming" noises like what you are experiencing are caused by a failing bearing somewhere. Some usual suspects are wheel bearings, alternator bearings, and sometimes even your waterpump, but usually it starts leaking too. To start narrowing down what it is, have someone ride with you to see if the noise is coming from left side or right side, or engine area, then see if it happens when the car is not moving, or just when the drive wheels are pulling the car? This way , hopefully you can pin point the culprit!
Mar 26, 2010 | 1999 Volkswagen Golf
When I start the movie the screen is dark and there is no vertical hold on the cyberhome screen
ur palyer is progressive mode u cahnge normal mode.press and hold stop button on ur dvd palyer front panel
Jan 26, 2010 | Cyberhome CH-DVD 300 DVD Player
I have a horizontal color line across the screen...have sound .This is on Video 1
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Dan
Apr 15, 2009 | Televison & Video
Samsung DVD player R 135 plays CD but not DVD
Laser pickup unit fault. Check and replace it. Contact any service technician. This is not an easy work that can be done by a user. http://electronicshelponline.blogspot.com/
Mar 04, 2017 | Samsung DVD-R135
''line in''
there is a switch that says line-line out. You want line out.
Nov 23, 2008 | Sony DVP-FX810 Portable DVD Player
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Mintek DVD-1810 Portable DVD Player \ Logo
71 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
