Question about Microsoft Windows 2000 Professional for PC
Error 5 1st The system encountered the following error while reading the list of shares:Error 5: Access is denied. how to come out and senond question is C:\PROGRA~1\MYWEBS~1\bar\1.bin\MWSBAR.DLL
  • Anonymous Feb 27, 2008
    .php extention file is not open
  • 51 Answers
Hi
check the permission of the share and also you may have to create a user just for sharing
This is a permission issue. If the net view command fails with a "System error 5 has occurred. Access is denied." message, 1) make sure you are logged on using an account that has permission to view the shares on the remote computer.
2) Need to cache credential: logon the same username and password on both computers or use net net use \\computername /user:username command.
3) Make sure the Netlogon service is running
the second question : it is a spyware
check this link in regards to clean t
Posted on Feb 13, 2008
Access privileges error message (-5000) while creating "Grooves" while translating MIDI Operation Data
During installation, I receive "Error creating file. 1008:5,-5000 Access denied error".
I share a link please visit and read web page i hope solved your issue.
http://support.dataviz.com/support.srch?docid=13157
Thanks,
Mac Support
May 28, 2014 | Apple iMac Computers & Internet
How to install openal32.dll??i try to extract to system32 but error access denied appear...can anyone help me??
You will have to login as administrator to make changes to system directories.So try doing it with an administrator account.If the error occurs even when you are logged in as administrator then
then follow these steps to turn off Simple File Sharing, and then take ownership of the folder:
  1. Turn off Simple File Sharing:
    1. Click Start, and then click My Computer.
    2. On the Tools menu, click Folder Options, and then click the View tab.
    3. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
  2. Right-click the folder that you want to take ownership of, and then click Properties.
  3. Click the Security tab, and then click OK on the Security message, if one appears.
  4. Click Advanced, and then click the Owner tab.
  5. In the Name list, click your user name, Administrator if you are logged in as Administrator, or click the Administrators group.
    If you want to take ownership of the contents of that folder, click to select the Replace owner on sub containers and objects check box.
  6. Click OK.
    You may receive the following error message, where Folder is the name of the folder that you want to take ownership of: You do not have permission to read the contents of directory Folder. Do you want to replace the directory permissions with permissions granting you Full Control? All permissions will be replaced if you press Yes.
  7. Click Yes.
  8. Click OK, and then reapply the permissions and security settings that you want for the folder and the folder contents.
Hope it helped.
Oct 28, 2010 | Computers & Internet
Files and directory listings on a Web Server
Without knowing what software you are using its hard to give specifics but it sounds like you need to change the permissions on the folder. You may have the "read" attribute set but not the "list" attribute, you can open the file if you know its name but not list the contents of the directory. Unfortunatley these permissions must be set from the server side.
May 10, 2010 | Computers & Internet
Run-time error'75' path/file access error .This keeps comming up trying to program XE-A203
Cause of the Error
This error message is generated only on a Windows computer when a read-only shared resource has share-level access control.
Resolution Methods
You can resolve this issue by using one of the following methods:
*Change the access permission on your shared resource from read-only to full control.
*If your Windows computer is in a Windows NT domain, you may use user level access to workaround the problem.
*You may use Win32 API calls to access your read-only shared resource on Windows.
Dec 01, 2009 | Casio Parts Cash Register PC Desktop
Print from vista to xp with usb connected lexmark 2350 results in access denied error after timeout. Vista access shared printer through a wireless router. Any recommendations?
Okay, I need to understand your topology a little better. You have two PCs, one using Vista and one using XP. Both PCs are connected to the Wireless modem. The printer is connected to the XP PC and shared across the local network? When the Vista unit sends a job to the printer, you get an access error message. Is this description accurate? Normally this would be caused by the sharing settings on the XP unit. Please make sure you have the sharing options correctly set on the XP unit and then get back to me if I've given you an incorrect path to follow. Don
Jun 06, 2009 | Lexmark X2500 All-In-One Printer
What does Windows Vista error 0x00000005 mean?
Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
( ERROR_ACCESS_DENIED == GetLastError() ) )
// Access Denied: Maybe the file system is not ready yet.
tries++;
if ( tries > 4 )
break;
Sleep(500);
// It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Microsoft Windows 2000 Professional for PC Logo
368 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
