Question about Sony KP-57WS500 57" Rear Projection Television
Blinking standby light (6 times)
Screen flashes bright blue b lacks out and corrects itself. now starting to shut off and light begins to blink. sound never cuts out.
  • Edizo Feb 20, 2008
    TV flahes 3 times and shut off but still have sound. What is the problem. I dont know if i should replace the bulbs
    Problem Solver:
  • 17 Answers
Sounds like the blue CRT is failing. You might be able to squeeze a little more life out of it by adjusting the blue screen control, but it will fail again very soon and the blue tube will need replaced.
Posted on Feb 14, 2008
Sony BRAVIA Fails to fully Power ON. TV shuts off when backlight should kick in, after logo lights and fades. 'standby' blinks 6 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Feb 29, 2016 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
JVC LT-40DG20J 42` HD TV wont turn on. I turned my TV on and no picture just blue flashing light, after hours of turning it on an off it came on, after 5 6 hours it shut off again, now there's NO flashing...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jun 28, 2014 | Televison & Video
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
Sony KP-57WS500 57" Rear Projection Television Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
