Question about Thermador C272 Electric Double Oven
Temp probe indicator stays on
The "probe installed indicator light" stays on when there is no probe installed. The upper oven will not operate without programing in the probe even though the probe is not installed.
  • dalernash Feb 13, 2008
    I don't have a GE oven and I did not change the temp reading from F to C. The indicator came on and stayed on during regular oven operation. The probe is not installed, why would I want to inspect it?
    Novelist:
  • 123 Answers
If you’ve accidentally switched the oven control on your GE oven from Fahrenheit to Celsius (or vice versa), it can seem like an oven control problem; the keypad will accept some temperature selections and not others. Easy enough to switch back to the way you want it– this excerpt from your owner’s manual explains the technique:
Your oven control is set to use the Fahrenheit
temperature selections but you may change this
to use the Celsius selections.
Press the BAKE and BROIL HI/LO
pads (on double oven models use
the upper oven controls) at the same
time for 3 seconds until the display
shows SF.
Press the BROIL HI/LO pad. The
display will show F (Fahrenheit).
Press the BROIL HI/LO pad again. The
display will show C (Celsius).
Press the START pad.
NOTE: On double oven models the new setting
will be displayed for both ovens.
Posted on Feb 13, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 13, 2008
    Can you inspect the probe.good luck
    Genius:
  • 3,587 Answers
Sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
  • Patrick Michaels
    Patrick Michaels Feb 13, 2008
    hmmmm...that sounds quite perplexing. So, if I have this correct, you have a unit, that without the probe installed, or when it is, still will not function. Am I inthe right space on this with you?
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
GE oven JKP26GOP2BG wont heat
either the temp sensor probe in the oven cavity it open/shorted or way off scale and telling the control board the units up to the temp set point,theres a way to test these with an ohm-meter for resistance at certain temperature but i dont have the chart for that test,it may be inside the unit if you can locate it
Dec 02, 2012 | Ovens
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
I own a Kenmore elite Model 790.4660 electric range. When I attempt to use the oven there is a beeping message "F30ERR" Thank you. Mark
Thank you for question. I understand your concern with your Frigidaire range. Without knowing the model number I can't be 100 percent certain but F30 generally implies an open oven temperature sensor probe. The oven temperature sensor probe is located inside the oven cavity in the rear upper left or rear upper right hand corner. It can generally be removed and disconnected from inside the oven cavity.
Check the wiring harness connections between the control board and the oven temperature sensor probe connector. Check the resistance or the sensor at room temperature with an Ohm meter, if less than 996 ohms, replace probe. Check with meter, for shorted probe harness between control & probe connector.
. I recommend calling a service technician to diagnose and repair your range.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services
Dec 29, 2010 | Kenmore Ovens
Oven is not staying at the set temperature. It will go as much as 200 degrees higher than set temp
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 04, 2010 | Kenmore 30169 Electric Single Oven
I have a Magic Chef Chateau Gas range. The upper oven does not heat properly. It comes on, but never gets up to operating temps.
you could have a bad ignitor check that it is actually igniting the gas and you can see flame, also check the cavity sensor a probe that sticks into the oven at the top usually on the left top corner but if the bake cycle works with good results them it is ok
check for flame when it starts give it a mibute to ignite, if it does not then you need to replace the broil ignitor.
Sep 19, 2009 | Ovens
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Thermador C272 Electric Double Oven Logo
1,349 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
