Question about Envision EN9410 19" Flat Panel LCD Monitor
Wont stay on
Hi i have the EN9410 19in flat panel monitor and today when i went and turned on my moniter it turned of for a second then flshed a little ad shut off and it would keep doing this over and over. I tried unplugging the cables and plugging them back in and i even tried it with just the power cord plugged in but I still get this problem. Also if I did not buy through Envision but i bought my moniter through a retial store like frys do i still have the three year warrenty through invision?
  • 3 more comments
  • iguanahotsau Feb 14, 2008
    this has nothing to do with my computer I just build a brand new comp last summer and in my post i said i tried it without it being plugged into the computer and the same thing still happened. i was using 2 monitors. Right now I am using my samsung 22" widescreen lcd so it has nothing to do with my computer.
  • Ima Geek Mar 12, 2008
    I have an Envision EN9410 19 in flat and last night we had a power outage the monitor was not hooked up to a computer although it was plugged into a surge protector the power button flashes and the screen remains blank. I have tried hooking it up to two different computers and changed the power cord....nothing works.
  • bmack 20000 Apr 02, 2008
    Yes I have an Envision model # EN9410. The screen went black while I
    was at the computer. It seemed to be working fine and then it just
    quit. My computer was stalled at the time. I turned off the power
    and unplugged and replugged the units. Still no monitor function. I
    plugged in another monitor and it workes fine. Is there anything that I
    can do at home to correct this problem? thankyou Brian
  • chylve Dec 02, 2008
    Same problem here. It started giving me problems yesterday and so I
    hooked it up to another system and it worked fine. Hooked it back up to
    mine and it ran all night without problems. But today it is doing the
    same thing, off and on. I tried dis/reconnecting all the cables with no
    effect. I hooked another monitor up to my system and it works
    perfectly, so it's not my computer. And now the Envision is giving the
    same problem with the other system, so...
  • Anonymous Mar 08, 2009
    Same thing, but the thing I don't get is if you hit the Auto Config button at the right time, the monitor will stay up for as long as it takes to config your computer
I can verify StephenG's response. All of the 470 mfd and 1000 mfd caps had vented. I replaced them and it works fine now.
Posted on Aug 25, 2009
    Problem Solver:
  • 10 Answers
I have the same monitor with the same problem, it would keep restarting up. I found 2 identical 470uF 25V caps that had vented and failed on the power supply board next to the edge. I replaced these and the monitor now works fine.
Posted on May 17, 2009
    Problem Solver:
  • 4 Answers
I pulled mine apart that has the same problem.
I noticed while the monitor was doing it cycling, i could hear a faint "winding up" noise each time. (Probably a capacitor)
Upon dismantling, i removed the poser supply, plugged in the power cord while the end at the wall was unplugged, set the unit on PLASTIC or GLASS, and plugged the wall end of the cord in. At this point i noticed the 1000uf capacitor was making some strange noise like a distant coffee pot steaming. I don't see any leakage, or bulging on it though.
The voltage readings on the connector read +12 and +5 like they are supposed to, but the 720VAC leads to the lights are at 0.
I am planning on trying a new cap once i can find one. Radio Shack didn't have one while i was there.
Note: Be careful when performing this kind of live testing! Large caps and bottom of board contacts are dangerous.
Posted on Apr 29, 2008
He said monitor not computer. its the monitor thats mess up. i got the same problem.
Posted on Mar 23, 2008
    Novelist:
  • 123 Answers
First unplug your computer from the wall and your monitor from the back of the computer. Open the case (this should only entail removing a screw or two) and locate your RAM modules. To remove a stick of RAM, press the tabs on each end of the mounting slot until the module pops out. First, remove all three RAM modules. Then, without replacing any, plug your computer back into the wall. Press the power button. If you hear a series of beeps, that's good. This means your motherboard is at least in working shape. If you don't hear anything, your motherboard is fried.
If you heard a series of beeps, begin by replacing the two paired RAM modules in the computer, one in the DIMM 0 slot and one in the DIMM 1 slot. Try powering your computer on with only these two. If this works, you could attempt to use the 256 stick in the DIMM 2 slot later, but if it causes an error like the one you had earlier, remove it.
As a side note, some of your components are at least seven years old (your GPU caught my attention). Most components are only designed to last 5-7 years so a complete failure of the video card might not be out of the question. In addition, an old motherboard might have trouble supporting a relatively new HD.
Post back once you've tried all this.
rate me
Posted on Feb 14, 2008
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor won't stay on
More likely to have problem in the power supply due to bad caps, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 01, 2010 | Envision EN9410 19" Flat Panel LCD Monitor
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Lt982s
Hi...there,
You've got a busted backlight inverter...
Dec 17, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
No picture. Yellow light stays on. No blue light !!!
the problem with the CPU might be the graphics card is down
u should check the ram connections....
also check if ur moniter works on other CPU's or not
if not then this might be a problem with the moniter
Oct 25, 2008 | Gateway FPD2185W 21 in. LCD Television
How to fix your speakers
Hi...there,
It's could be your LCD Monitor got surges inside...
Turn off your computer and unplugs all the cables from the monitor and computer too. Wait for 10 seconds... then reconnecting all the cables back and turn on your pc. If that doesn't solve the problems... then open the back cover to checked any loose audio cables. Good lucks!
Sep 07, 2008 | HP Vs17 17" LCD Flat Panel Monitor
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Hp flat panel monitor looses picture
Here
Here
and Here
I've tried all the aforementioned fixes, and my conclusion is... when your monitor's dead it's dead. Go to NewEgg and and get a new one.
Nov 12, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Envision EN9410 19" Flat Panel LCD Monitor Logo
484 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
