Question about Panasonic DMR-ES40V DVD-Video Recorder
Error Code F03
The unit will not do anything... even after unplug and reboot.
  • 1 more comment
  • johnyrotten May 31, 2008
    Panasonic DMR EZ475V with an F03 code even after shutting off and rebooting how do I fix
  • bent_fabric Jul 01, 2008
    same error code, but with a panasonic dmr-ez48v. have rebooted, but won't go away.
  • Anonymous Oct 10, 2008
    Same problem as above!
What worked for us when we saw F03? Taking the toothbrush out of the VCR! I kept resetting the unit and nothing worked. Finally, I decided to see what would happen if I stuck a tape in. It wouldn't go in because of the toothbrush! I took it out, reset the unit again and it was fixed.
Maybe the error is not F03, but FO3 meaning there is a FOREIGN OBJECT stuck in the VCR.
Posted on Oct 10, 2008
I came here with the F03 code and got read the message about foreign objects. I took off the cover and manually removed the tape from all heads and rollers. Then it was easy to eject. I found nothing wrong with the innards of the machine, so I checked the tape. Inside the tape cartridge was a dead stink bug which had cause the tape to tangle and jam. Since this was at the very beginning of the tape, I wound all the bad section onto the take up reel and will watch the rest of the tape, then junk it. Thanks for the ideas.
Posted on Jan 29, 2012
  • Brett Barkus
    Brett Barkus Oct 31, 2013
    Had same F03 code and could not get unit to reset. as suggested above I took the cover off and found a small plastic part off a toy tractor. cleaned it out, put it back together and it is again working perfectly. Dont toss your unit out without opening it to check for any small objects hiding inside.
I had an F03 problem earlier this morning. and I just found out the solution:
It is the faulty tape, the tape layering on the top of the roll is the cause of the infamous f03 code. What I'd do is this:
1. Unplug your VCR.
2. Remove the chassis by unscrewing the screws that keeps the outer cover in place.
3. Carefully move the ribbon of the tape away from the points without touching the sensitive areas.
4. Press the eject button manually and slowly remove the videocassette out of the VCR.
5. Slowly put the chassis back on the VCR and carefully align the holes to secure the screws back on.
6. Carefully rescrew the screws back to the appropriate area once you unscrewed them.
7. Plug your VCR back in and hook it up like normal.
8. Utilize the head cleaner to secure the optimal VCR performance. Clean it as much as it needed to be in case once is not enough.
Posted on Sep 27, 2011
  • tain
    tain Nov 02, 2014
    bad
In my case I did not have a VCR tape or a disk inserted in the machine. The recorder displayed the code for months even tried to call Panasonic and they told me to ship it to repair from Michigan to Texas!. I found this site and codes,got confused since nothing was inside and tried to turn it on again after checking for any residual tape fragments or disk fragments and found none. It works! Maybe it needed a break. I am surprised Panasonic did not tell me to check for foreign objects.
Posted on Dec 08, 2014
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Wont do anything getting F30 error code
Do you mean F03? that error is known in Panasonic video products. It usually applies to the VCR, which means a mechanical fault; such as loading motor and/or mode switch. The switch itself would be on the main board under the VHS deck, and can be cleaned with special electronic spray cleaner, and electronic lubricant (after the cleaner), but for more reliable results, the mode switch may require replacement, which should be done by a workshop. If this is the only issue you have with your combo unit, it shouldn't cost too much to correct this problem. Either try cleaning the switch yourself (being careful when opening unit), or submit to workshop for quote and professional repair.
I have never heard of F30 as a video/DVD error code before. That error applies to some Panasonic air-conditioners and is a system error.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
All of a sudden my MP500 gives an error code
If the carriage will come out of the right corner, you need to look inside and see if there's a paper scrap or anything blocking the purge assembly. The purge is the unit that cleans the printhead, and that error says it's not moving properly. If nothing is stuck in there, you will need to have the purge assembly replaced.
Dec 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
My front load Kenmore washer has a f03 code on the screen. It is not draining the water and it is not doing a max spin. What do you think I need to do?
F03 error code means that there is either fill problem, a drain problem or a water level pressure switch failure .
First ensure the machine is filling.
When the drain system is causing the F03 error do the following.
Ensure that the drain hose is not kinked or clogged.
If the drain hose is OK check the drain pump.
Start unplugging washer from main and remove the service panel at the bottom.
Follow the instructions on manual to remove panel.
Access the water pump and remove the hoses, clear any blockage in there.
Use a container to collect the water, be prepared. If machine has lot of water inside, remove some water with a sponge before undoing the pump.
Sep 27, 2009 | Kenmore 46462 Front Load Washer
VCR keeps showing "F03" and doens't do anything
Your vcr seems to use the K Mech. F03 Means that the mechanism locks when unloading.
The cause of which might be the loading motor or drive, timing and most likely the mode switch.
Jun 02, 2009 | Panasonic Televison & Video
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Error code F03
although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
Mar 16, 2008 | Ovens
DMR-ES40V Error Code F03
This means there is a technical error.
I suggest you go to your nearest retailer iof this and they will fix it but they will probably charge.
Hope this helps! - Josh
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
3,081 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
