Hitachi 50" MTS TV/Monitor
TV would only turn on sometimes even with remote. The person i got it from use to hit it above the on off switch on the grey plastic frame and it would turn on only to shut it self off. The same thing happens every time it gets turned on. Now it doesnt turn on at all. Frustrated i still feel the tv will work. Please help
  • joyriider Feb 13, 2008
    thanks for trying
  • 84 Answers
It's possible you may have bad solder connections on the chassis boards.
C-Dog
Posted on Feb 13, 2008
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Pink color on projection TV
Okay, I'll give you the easy fix and the permanent fix here. Easy fix - accomplish what those guys do, without the laptop: Turn off the set. Hold down the Menu/Exit button while you turn it on. Release the button a couple seconds after the set comes on. That brings you into the service menu. Hit menu on the remote for more options. Scroll down to Memory Init. Check the box next to that to clear the pink. Then hit exit on the remote to exit the service menu. I'm still looking up some specifics on the permanent fix - I'll get back to you.
Sep 06, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a Hitachi SBX Ultravision 50" rear
This is a very common problem on your Hitachi model and an easy DIY fix. You can get the correct parts and instructions for this exact fix on www.TvRepairKits.com
Jan 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
Will not turn on and not sure why
There's a chance that when the Tv doesn't turn on, it might be because the power supply might be defective, but for a more exact info i'm missing more details, discountdashmerchantdotcom, try it they'll troubleshoot you for free and you'll see what's the issue with the tv
Jul 09, 2009 | Hitachi 50UX58B 50" Rear Projection...
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
Sanyo MTS TV
Hello
Most universal remotes should have a TV/Video button. Look carefully on the remote. Or get another brand remote.
Also depending on your Sanyo model there may be a TV/Video switch on the front of the set. Look for a possible small cover along the bottom.
Feb 26, 2008 | Televison & Video
TV won't turn on with remote
Unplug your set from the wall and wait a few minutes. This fixed the same issue on my 50V715
Oct 10, 2007 | Hitachi 50V715 50" Rear Projection...
Sayno Tv
You didn"t say already working in AV mode or not. Suppose if it is worked means this is the simple one just change programme (-) button in TV front panel till becomes 1 or 0. After 1 or 0 again you press down the same button you get AV mode. Even you won"t get try in menu features to change AV mode. Even you won"t get there is a problem in Micom section. Technical persons only sort out your problem by changing EEPROM ic. I hope the above information is useful to you.
Sep 02, 2007 | Sanyo DS31520 31" TV
Hitachi 50UX58B won't turn on
try checking c707 you have to look close they go bad look around it i had the same problem a small pin hole burn in it
Sep 16, 2006 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
