Question about Mitsubishi WS-65711 65" Rear Projection Television
TV Shuts off by iself!
Mitsubishi WS-65711 TV turns off by itself. We had the convergence chip replaced about 8 months ago. The problem has gotten considerably worse over the last month. I noticed horizonal lines at random points onthe screen before it shuts off... We have tried resetting & unplugging the tv. Nothing works. Any guidance would be greatly appreciated. TV is only 4 years old. WILL NEVER BUY MITS PRODUCTS AGAIN after this bad experience. TV never moved since purchased new!!!
Thanks,
Larry P.
  • Musicman0517 Mar 16, 2008
    Just an update... We have done nothing new with the TV and it has worked perfect for close to a month (so far)! I have no idea why it woukd shut off consistantly for 1-2 weeks nd then work perfectly for a month. My wife said it did shut ff once a few days ago but has been fine since. Loose connection??? We did have the convergence chp replaced over a year ago...?
    Any ideas???
  • 579 Answers
Don't feel bad about Mits. All the projection companies and all the new TVs have markedly poorer reliability than the good old CRT types. You should see all the class action lawsuits against even some of the best companies!
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Feb 13, 2008
Red distorted color near top of screen not having much luck with trying to converge the lines on the tv set form. already tried factory reset
Reset will not cure a convergence problem.
this model (ws-65711) uses a single convergence chip located on the middle circuit board (see photo).
If convergence is skewed and will not adjust in customer menu the chip needs to be replaced.
Good news: I have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do the repair.
No two sets with convergence problems will look exactly the same but I will also attach a few photos of this kind of trouble.
If the photos or what I have told you told you something you did not know and you want the instructions (free) rate this solution as very helpful as I do this here for free.
SD TECH
31e1a0a.jpg CONVERGENCE CHIP USED IN THIS MODEL.
3215424.jpgTYPICAL BOW FROM CONVERGENCE PROBLEM
ANOTHER SET WITH CONVERGENCE PROBLEMS
Sep 14, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Mitsybishi WS-65711
i believe i staed ina similiar case that you seem to be having a over heating of the circuit chips on the mother board. are the cooling fans in the set running.
Aug 30, 2008 | Mitsubishi WT-42315 42" TV
Tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Televison & Video
Tip
Bypass Mitsubishi WS-65711 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
I have a WS65711 - 3 months ago I replaced the Convergence - Today the TV was on then turned itself off. I have tried to turn on but it just turns off after 30 seconds
Did you do the diagnostic self check:
when green power light goes off on the front of the set press and hold both Menu and Input(Device) buttons for 5 seconds and release both.
Power light will blink two digit error code like: 2 pause, 2 and repeat it at least 5 times.
Let me know what code you find and I will try to help you.
SD TECH
Jan 05, 2010 | Mitsubishi WS-65711 65" Rear Projection...
I have a Mitsubishi WS-65711 that is six years
Go by number on your ICs If they are STK392-570 then use STK392-570 only! Call Mats for parts 10.95 each 1-800-628-1118 They are Big Black ICs mounted on Big Aluimmim heat sink will have STK on them!
Dec 27, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Tip
I hope that helps.
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
I hope that helps.
I have a Mitsubishi Tv, WS-65711. The colors have
Ur convergence it dead.Must change the convergence ICS.Know how to solders?Buy a convergence kit,use what in that kit.Tries these websites.Tv repair World.com,Tv Repair kits.
Nov 10, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Mitsu Proj TV WS-65711 needs Converg IC chip. Part Co$t + labor?
There is either a pair of STK392-570's, or
a STK393-110. Probly also 1 or 2 pico fuses for the +/- 26v line in the power supply.
Parts aprox 80.00 to 90.00
Labor 150.00 to 180.00
Plus service call fee if any.
So figure it up from there. Labor cost does vary from location to location. I do feel confident that capasitors are not causing this problem in the way you explained the symptoms.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi WS-65711 65" Rear Projection Television Logo
233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
