Question about Archos 605 WiFi Digital Media Player
Cannot play file! File is corrupted.
Every time i upload pictures or have movies that are the proper format they dont seem to work. Whenever i try to open a movie file it says "cannot play"
and when i try to open a picture file nothing happens!
I investigated by going through my file directory and looking to see if the problem started here, i tried looking at the info and tryed opening them there, same problem except it gives me the error: "cannot play file! File is corrupted."
If anyone has had or has a similar problem like this please i would appreciate your feedback.
  • 4 more comments
  • atb0826 Feb 21, 2008
    When I try to play certain wma files on my Archos I get a "Cannot play file! File is corrupted." message. When I transfer said file to my pc it plays perfectly fine. Anyone know the reason?
  • Anonymous Feb 28, 2008
    d music downloaded will not play or cancell file corupt I am old and rubish on computors please help also unable to find up date manual for 605 many thanks harry
  • Anonymous Mar 03, 2008
    When I download a movie onto my player in AVI format and then click to play it, it comes up as cannot play. Corrupted file. I used to be able to just download and open to watch, now are my movies are saying the same thing and I cant open anything on my player even pictures. Please help!!!
  • fishfreek Aug 02, 2008
    After loading music on my Archos 4GB, I tried to play the music...the system said "File is Corrupted! Cannot Play File". Please help
  • djtyrone Aug 07, 2008
    yep same problem
  • peter_chin Aug 27, 2008
    I get the same message when I click on links to video clips on my web page. The clips play without any problem when I click on the file directly.
    Peter
I had that problem with music files. Said corrupt file whenever I played in shuffle/all mode. I fixed it very simply. Here's how.
On your screen (not computer, just your 605), open Menu, then hit Settings. At the bottom is System. Open that. When you do, you'll see your system info. There's a button that says "Update ARC Library." Hit it. It will take a few seconds, but you'll see everything new you've loaded being updated quickly. After I did that, I had no more problems. Hope it helps on your music, and also any other problems. paul4laffs
Posted on Aug 06, 2008
    Problem Solver:
  • 7 Answers
Here is a general and easy fix for this...in my own case neither video nor picture files would display at all(wouldn't even attempt it)-immediate error msg to the tone of "cannot play" "file is corrupt"....
turns out the archos just needed to be rebooted...you can do this by going to settings on main screen...then select power...now press "device complete power off" and it will shutdown(e.g. NOT suspend mode as is normal)...give it a couple seconds once off...turn it back on and when it boots up it should be ok again.
Other than this you're most likely looking at a problem with the drive itself, which is bad, because from my personal experience the archos rma process royally sucks.
(you will generally receive a refurb unit rather than your unit repaired, which is fine except that EVERYTHING about the archos is linked to the product key and serial of your unit so if these change, which they DO if you receive a refurb, literally nothing you have for the archos will work properly anymore, including the dock...a month later I am still in the process of getting archos to fix all the problems associated with this simply because they don't apparently update their records when they replace your unit...or when you have to call them the first three times...lovely!)
Posted on Oct 19, 2008
Wow, I came here with the same problem three hours ago. I couldn't even connect to my Wifi at home.
I actually had the machine running for over 36 hours, plugged into a wall jack, when it finally freaked out like that.
I decided that I should just let the beast cool off, I gave it a couple of hours, unplugged, and when I tried it a couple of minutes ago it worked like a charm.
I don't know how long it takes for this sort of "over heat" to happen, but the cool down worked like a charm.
Posted on Apr 22, 2008
Connect it to your computer in hard drive mode
go to My Computer
Right click on "A605"
Select "Properties"
Select the "Tools" tab
Click "Check Now"
put a check in both boxes, click start
no go find something to do for THREE hours
running a defrag (also in the tools tab) may not be a bad idea afterward.
Posted on Mar 20, 2008
You have to down load the plugins for it to play most files to play on it
Posted on Mar 03, 2008
Fgtge
Posted on Feb 14, 2008
I have all the plugins except the internet plugin
I hooked my tablet to my tv usb after downloading some movies some will play some not
Did you download in tablet or computer? Are those movies olayable on computer? If they play on computer it would mean that your tv cannot handle certain codecs or formats and you need to re-convert those movies to format understandable by tv. If they dont play on computer then either file is corrupted or you downloaded "fake" movie
Oct 07, 2016 | Tablets & eReaders
Cannot see pc MOV or JPG files on flash drive in Canon SX230
Thanks very much for responding to my problem.
It seems Canon will not allow edited pictures or video to transfer from PC to their digital cameras for viewing.
steps to my problem:1. my canon SX230 created all the parts for my WMV video in MOV format originally.
2. created a movie (WMV format) in Windows Live Movie Maker. Works well and plays on my PC (windows 7).
3. after WMV completed - converted to HD MOV format in 2 different file convert programs and with 2 different HD MOV resolution settings on Both programs. WMV resolution is 1920x1080 (HD). ALL 4 MOV videos play well on my PC in 2 different programs.
Steps getting Canon to see video in playback mode.1. copy MOV video from PC to Flash drive in my card reader in same folder as my original JPG & MOV files, then inserted into camera - does not recognize file.
2. copy MOV file from PC to camera with USB cable. Windows error message. Wrong format - would not copy.
3. Formatted flash drive in camera. Took picture to create DCIM folder, JPG image, and CANONMSC folder with M0104.CTG file .Deleted CANONMSC folder. Copied my MOV video from PC to camera (USB cable). this time copy successful. However camera does nor recognize file.
5. tried again except deleted M0104.CTG file but not the CANONMSC folder. no luck.
It seems Canon will not recognize any file that has not originated in the camera AND has not been altered. Upon researching answers on the NET - many other users of Canon cameras have the same problem with no luck.
Apr 23, 2012 | Cameras
I try to add music to my picture movie through windows movie maker but each time error:0x87160129 keeps popping up.movie will play but without music.Please help.
Program requirements before music, videos are displayed together on a computer
1. A music editing software separaly installed on the computer
a. the music files would be extracted from disk mediums by music editor software.
b. a versatile music editor software would provide format conversions
c. a music editor software that makes possible clip extractions to be integrated onto another program
2. A movie editing software separately installed on the computer.
a. a software that recognise verious file format in music and videos
b. a versatile video editor software would intergrate music from another software
Important notes
1. Music file formats are selected compartible to the video editor software on which to be integrated
2. Files have to be edited and stored at a separate computer folder like my documents, my briefcase, or personal file folder
Initial diagnostic checks
1. The music file is in an incompartible format, performing a file format convertion should resolve such an issue
a. software multimedia converters are acquirable to be installed separately
2. the music file is corrupted, selecting another would resolve the issue
3. performing the video creation precess altogether would fix any error. Discard the video created, and rebuild a new compilation of music and videos.
a. notice any file errors requiring fixing
Dec 20, 2010 | Computers & Internet
Format external memory
the problem can be solved.For the video not to be able to play might be due to the video file being corrupted or the memory card was not really formatted properly.
You can format the memory card again and try transferring the file into the memory card.If it does not work, try and use another device to format it.
If still it does not respond properly, then the memory card is corrupted and it needs to be replaced.
Have a nice day.
Mar 16, 2010 | Insignia Sport MP3 Player
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Downloading music into Kingston 2GB SD card on Nokia 6234
It's possibly not properly formatted type of AAC file that uploaded into your cellphone, that when you try to play the cellphone cannot support to play it and that it gives a messages like corrupted type of file..
Hope it helps
Enjoy!
Pls. rate and hope to hear more from you
tnx
-micro
Feb 10, 2008 | Cell Phones
File Error
File error means it cant read the file or the file is corrupt, i would try a new memory card or format the one you have.
Feb 07, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Video Upload problem
Yes u can say that.The files can be of avi or wmv format.After that use Samsung media studio to put these files into your yp-t9.The samsung media studio shoul convert these formats into svi format which can be played by the yp-t9
Sep 27, 2007 | Samsung YP-T8 Digital Media Player
I can't upload 505v movies to PC?
Did you go to Mssony directory and Moml0001 folder to look for the mpg file? I have a F505V and it works fine with my USB in Windows 98.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
Archos 605 WiFi Digital Media Player Logo
1,818 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
