Question about HP Officejet 4355 All-In-One InkJet Printer
Printing I cannot print my word document file rom my pc
  • Anonymous Mar 18, 2008
    printer not function
SELAM
Posted on Apr 10, 2008
How to print documents from all-in-one pc
All document creating programs have the option to print. Simply, click on file-print or the little picture of a printer.
Feb 24, 2015 | Microsoft Computers & Internet
Hp deskjet 930c printer
Printing can be a rather tricky process. If your planning on printing a document, press 'File' then 'Print Preview'. Once your happy press 'File' again, then press 'Print'. Connect it to your printer. Before printing, check that you have paper and ink.
Jul 29, 2013 | Dell Inspiron Computers & Internet
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type Normal.dot or Normal.dotm depending on your version of Word.
  4. For each occurrence of the Normal.dot or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template (Normal.dot). However, existing documents that were created by means of your old Normal.dot file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
When printing from word the paper jams in printer.. works fine in all other programs
I work at a printing center at my college, sometimes this happens to the students that print. When printing it could be the word document itself: the file could be too big, or the printer could be reading the file wrong. Try saving the word document to a PDF (Print, Print as PDF), then try printing it. That way the printer reads it as a sort of image and not a .doc file, or .wrd file.
May 04, 2011 | Microsoft Office Word 2007 Full Version...
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
Prints documents straight from PC, but printing from internet bad
Try to save the save the page into single file then try to print.
Aug 19, 2009 | Samsung CLP-300N Laser Printer
Ping works, I can see the html page in the AR-205 but can't print
If you connect the machine to network via AR NB3 and EB 9, go to key operator program in the html page, hopefully the password still the default "Sharp", try test page printing. Also check the account control from the machine's panel by pressing special function, key operator program, password ( 00000 ) account control and un-check the account control for printer.
Jun 06, 2009 | Sharp AR-M205 Copier
After installing the HP PhotosmartC5280 All in one printer we can get it to scan and print from new documents. Yet, when trying to print from a saved file we receive the message that we do not have enough...
Try to delete unnecessary files on your computer, coz your computer is low in memory. open up your printer if theres a pending document then try to clean or empty it. boot your pc. Then try to print your document.
Nov 29, 2008 | HP Computers & Internet
Printing
Hi Pepin,
If you are using any document for printing open the document file and manually increase page size at page setup option of file menu.
Sep 25, 2008 | Computers & Internet
Printing from pc
Perhaps you are giving the Print command from Print icon on your Standard toolbar and your document is too big. Try print from the file>Print and select print current page. If the problem persists, reinstall the printer driver after uninstalling it.
Feb 06, 2008 | Office Equipment & Supplies
HP Officejet 4355 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
