Question about Acer AL1916W 19" LCD Monitor
Annoying discolouration across monitor
My Acer AL1916W has developed some strage red discolorations across the screen. They move on approximately a 45 degree angle from the top of the screen to the bottom. This discoloration covers nearly the entire monitor.
The discoloration is most noticeable on white backgrounds whilst hardly visible once I am playing games.
I have connected the monitor to both of my computers with the same result each time. I have also used different power supply and monitor cables for each computer with the same result.
Any suggestions would be greatly appreciated
  • 180 Answers
Does your monitor uses external Power Supply Unit ?
May be the video board need services.
Posted on Apr 19, 2008
My al1916w monitor has a vertical blue stripe on the left side. It works fine except that the striped area discolors video. How do I fix that?
Unfortunately, a stripe on an LCD monitor indicates a physical failure of the LCD panel itself. The only solution is to replace the panel with a new one.
Apr 12, 2011 | Acer AL1916W 19" LCD Monitor
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W monitor the screen is cracked in the middle.and I want to replace the screen thank you.
You may have to order that directly from acer. These crt for monitors are not interchangable.
Jul 01, 2009 | NEC MultiSync FE991SB 19" CRT Monitor
Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Apr 03, 2008 | Acer AL1916W 19" LCD Monitor
After any game, and go back to XP, my monitor go like 8 bit color,have to power down and up
Try useing a different resolution. The native resolution should probable be 1280 x 1024. Try updateing the video drivers.
Nov 23, 2007 | Acer AL1916W 19" LCD Monitor
Annoying Nuisance on the monitor
Run your system in 'Safe Mode'. Go to Display settings and set lowest possible resolution. Then restart computer and run windows again in normal mode. Should have normal screen. If this will not work - then under safe mode uninstall graphic card. Then run windows with standard ones and in LOWEST possible resolution install drivers again. I have had it many times and it made swear first time.
Oct 28, 2007 | Acer AL1916W 19" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
241 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
