Question about Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
Does anyone have experience connecting Bose 901 (non-powered) speakers to the JVC RX-8020VBK receiver either as front speakers for surround or just as standalone stereo speakers. I can't find a Tape Monitor switch to use. Don't have a tape deck either. I only see pre-amp out connections - no amp in.
Thanks for your help!
  • 4 Answers
In order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Posted on Feb 13, 2008
Would a Yamaha RX-V1 drive the Bose 901 Series VI speakers well?
The Bose 901's can handle up to 450w per speaker, using the Yamaha receiver, would not be MY first choice. Considering you invested in bose for a the quality of the brand, don't short change it like that with a lower powered receiver. NOT saying it won't do it, IT WILL, HOWEVER, if you really wanna see what those bose can do, get something more than the Yamaha RX. (110 watts)
Speakers like power, its best to run them at a minimum of 225watts. the closer you get to the 450w the better. 110watts is just too low, and can damage the bose. HECK, under powering ANY speaker can damage it QUICK!.
Oct 14, 2016 | Bose Audio Players & Recorders
How to connect it to NAD C-372
Download manual from the Web.
Follow instructions.
Enjoy.
Jan 12, 2016 | Bose 901 Series VI Direct/Reflecting...
What's will be the power output of a power amp ideal for Bose 901 Series VI if the specs say it's compatible wt amplifiers/receivers rated from 10-450 watts RMS? Rated 250 IEC.
Depends on how loud you want to play it and how large your room is. If you have a large room and like to see how loud you can play it, go for a lot of watts. If you mostly listen to soft music, and have a small room, 10 or 20 watts is enough. There is no "optimum" for the speaker, only for you, your room, and your preferences.
Jun 08, 2015 | Bose 901 Series VI Direct/Reflecting...
Is it safe to use a power Amp wt a power output of around 640 watts/ch for Bose 901 Series VI? I was told that the there is a plus factor on the maximum power output of 450 watts.
Just because you have 640 watts capability, that doesn't mean you have to use all 640 watts. Most of the time, you will likely use 1 ot 2 watts. Don't turn it up just to see how loud it will go, and you won't have any problems.
Jun 07, 2015 | Bose 901 Series VI Direct/Reflecting...
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
317 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
