Question about Dryers
Amana dryer heating element
The dryer will run but won't heat. I checked the black thermal cutouts that were suggested on other threads and found continuity (are there only 2?). But when I check for continuity at the heating element I found that there was none. I checked by touching the black wire and the first orange wire coming into the element. But when I tried the second orange wire (after the resistor looking thing) I found continuity. Should there be any? The coils are also showing they're age so I am prepared to by the whole thing if that's the problem. Should I check anything else before I order? Thanks in advance.
  • 240 Answers
Sounds like it is your element. If you got no continuity, that would be it for sure. Let me know if you need any other assistance.
Posted on Feb 13, 2008
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
LER7646 won't heat. I checked the resistance of the heating element (12ohms). The high limit thermostat reads 0 ohms and the thermal cutout read open on the ohm-meter. I replaced the thermal cutout and...
A typical reason the thermal cutoff would go out so quickly is because of a poor airflow so the heat is being built up in the dryer instead of being vented out.
What to check is for a blocked/restricted vent,lint built up in the blower housing that is restricting the airflow& or a broken blower wheel that isn't moving the air from the dryer.
GENE
Sep 05, 2011 | Whirlpool LER5636P Electric Dryer
My electric dryer runs but no heat.
Hello there:
There's no heat If your dryer doesn't heat, check these: Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
I will post the pictures of the heating element in a seperate post
Best regards mike
May 27, 2010 | Amana NDE2335AY Electric Dryer
My Amana PLE8407W2 doesn't heat.
If the fuse rattles, that doesn't sound good, but the easiest way to check is with an ohm meter, or multimeter which you can get at walmart for like $10, and you should own one anyway.
Oct 15, 2009 | Dryers
My electric dryer is not blowing heat, just cool air. What is wrong with my dryer.
Check the following to address this issue.
1. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 23, 2009 | Amana Dryers
No heat electric drier..dial moves model LEA10AW
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Sep 21, 2009 | Amana Dryers
Our dryer is running but it is not heating up
Check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is just inside the rear of the dryer usually attached to or near the exhaust duct. Both components can be checked for continuity using a multimeter or ohmmeter. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Aug 29, 2009 | Amana Dryers
I have a Amana DLE330RAW everything works, but it won't heat?
Jun 13, 2009 | Amana DLE330RAW Electric Dryer
Dryer not getting clothes dry
this will most likely be a problem with the heating element or a thermal cutout which are usually located on or around the element.some makes have cutouts with a reset button whitch when pressed will restore heat.
Nov 05, 2008 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
