Question about Garmin StreetPilot C320 (010-00401-00) GPS Receiver
Dead Garmin My C320 won't turn on, or even say that it's charging when it is plugged in. It seems as though it is dead. Last time I used it, the batteries weren't even low, and I turned it off after using it... only to find out that it won't even turn on or charge the battery. Any way to fix this, or even reset it? Thanks!
  • 5 more comments
  • luyj97 Mar 01, 2008
    Same here. Dead suddenly and can not turn on.
  • Anonymous Mar 04, 2008
    i left my GPSmap 60CS without batteries for 6 months and now it does not start. It makes a short flash on the screen and nothing more.
    ndrags@yahoo.com
  • cazador78 Mar 11, 2008
    Mine new c320 loaded maps and even planned a trip but now won't turn off and is not recognized by PC.???
  • jknjoesmum Mar 13, 2008
    I have the same problem. Mine is a little more than a year old and its been working fine and then yesterday couldnt get it to turn on at all and today if I try to power on I just get a flash of light or the home screen flashes but thats it. HELP!!
  • Anonymous Mar 25, 2008
    it worked when I shut off the car. Took it with me and would not turn on again when I replugged it in.
  • timothybills Dec 31, 2008
    Mine powered off on its own with plenty of battery left and would not come back on. Followed the advice of another post on Fix Ya and took the blue bezel (front cover) off and held the reset button for 5 seconds. It then power on fine when I pressed the power button.
  • bgman Jan 23, 2009
    My 320 was fine yesterday. This morning it would not turn on or give me any sign of life.
I had the same problem - worked great for a year and yesterday was totally dead - not a hint of powering up.
I pulled the blue front "frame" off and held the reset button for about 5 seconds. It powered back up and works like a champ!
-Johnnyx
Posted on Jun 07, 2008
I put mine on the car charger overnight and it started responding again.
However it lost most of the maps I loaded and when I tried reloading, I got an error message. I sent it to Garmin and they said the install was corruped and gave me a procedure to clean my registry and files.
Instructions are slightly less complicated than learning to fly a 747. But what choice do I have?
Cazador78
Posted on Mar 25, 2008
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
CHARGING MY GARMAN GPE C330. DO I LEAVE THE GARMAN ON OR OFF WHEN CHARGING . THE BATTERY WAS DEAD ON MY WAY BACK FROM MY LAST TRIP.IT WAS OK GOING UP I HAD IT PLUGGED IN TO CIG LIGHTER BUT GARMAN SEND...
Disconnect from cigar lighter and connect to the USB port of your computer or any AC adapter over night. By morning the battery will have recharged and be ready for use. This seems to happen with the GPS is left connected to a vehicle's cigar lighter for an extended period of time. You can do this USB / AC adapter recharge procedure as often as needed.
I hope this helps!
Jun 08, 2010 | Garmin nuvi 250W GPS Receiver
Battery goes dead after 3 hour use
As the battery charges and charges the charge time declines. You can get a high capacity battery for your garmin for about twenty dollars here:
http://www.megacapacity.com/23903.html
May 07, 2009 | Garmin StreetPilot C330 GPS Receiver
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Power cord doen not seem to recharge Garmin Nuve 680 in car.
to register my Garmin Nuvi. I want to get it registered, I tried before I'm not sure how far I got if it is registered or not
Jan 15, 2009 | Garmin Nuvi 680 GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Abnormal Powerdown Error Code
Your battery is dead, which is causing the problem with "slow to receive satellites". Normally when you turn off the unit it will remember the last location and time, then the next time you start the unit it already has the time and current location to acquire satellites, but with a dead battery it has to start from scratch. Check the screen and see if it says "Locating Satellites" or "Acquiring Satellites". Locating satellites will take longer. Replace the battery and your problems should go away.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C320 (010-00401-00) GPS Receiver Logo
490 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
