Question about Lexmark C752dn Laser Printer
Lexmark C752DN When I do an alignment to pick the best settings the magenta settings can never be set straight . There is never a best line to make an alignment. Page 1 F there is no best setting and page 4 K and L there is no best setting ,were the lines will not match up. When we print out graphs there are white marks were there should be color. The printer has had a new magenta head , fuser, rollers, transfer rollers, mainboard & cartridges.
    Genius:
  • 2,035 Answers
Follow the steps in htis link it may help:;;
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:409:0:0&framed=&docid=ENUS21576&relevance=1
Posted on Mar 21, 2008
Lexmark platinum pro905 fax
If you're having problems sending faxes, make sure that the printer is connected to an active phone line. The best setup would be to connect the printer straight to a wall jack and the other end of the phone cable should be connected to the line port at the back of the printer.
If you're having receiving faxes, check the fax settings > Ringing and Answering. Check if the Auto Answer is enabled and check how many rings the fax will pick up any faxes sent to your number. If you have an answering machine connected to the same line, set the printer to pick up 3 rings higher than your fax machine. If you have a voicemail service, you'll need to get a distinctive ring feature from your phone provider.
Oct 29, 2012 | Lexmark Platinum Pro905 multifunction...
How do you get the fax machine to work?
First, make sure that the printer is connected to an active phone line. The best setup would be to connect the printer straight to a wall jack and the other end of the phone cable should be connected to the line port at the back of the printer.
For receiving faxes, check the fax settings > Ringing and Answering. Check if the Auto Answer is enabled and check how many rings the fax will pick up any faxes sent to your number. If you have an answering machine connected to the same line, set the printer to pick up 3 rings higher than your answering machine. If you have a voicemail service, you'll need to get a distinctive ring feature from your phone provider.
To get more information on how to setup the fax, check this manual: http://bit.ly/PCKt7z
Sep 05, 2012 | Lexmark "x264dn multifunction laser...
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
My Brother MFC-490CW prints magenta where it should be printing black. I have done numerous cleanings and alignments. I changed the black cartridge and it is a Brother cartridge, not a refill. Still...
Well, either your print settings have it set to print in a color model that is not the native one (I can get this from CUPS drivers by picking KMCY instead of CMYK, among others) or it is confused enough to need Brother's initializing tool (program, I mean) to get it sorted out. Try de-weirding your settings first, then double-check the print dialog's settings when you retry. Nobody loves magenta-on-white for print.
Jul 25, 2011 | Brother MFC 490cw Color Inkjet...
Alignment problem
  • Turn on your inkjet printer and select the "Printer Assistant" program from your computer.
  • Choose "Utilities" or "Tools and Updates," depending on your software.
  • Select "Calibrate" to start the calibration process. It may take a few minutes.
  • Examine the printout and follow the instructions on your computer for how to pick the best printout. You will have to choose the straightest lines on the page and let the software know which lines are the straightest. Your printer will print out several more pieces of paper and ask you to find the straightest lines. Keep doing this until the lines on the test page appear straight.
  • Jan 13, 2011 | Lexmark X7170 All-In-One InkJet Printer
    How can I reset my Lexmark x2600?
    Usually, resetting the printer means turning it completely off and turning it back on. I would also suggest unplugging the machine for a few minutes, and then plugging it back in. Then, turn it back on, and it will run through a set of steps that will re-align the heads on the cartridges automatically. This will clean the ink residue from the cartridges and align the Cyan, Magenta, Yellow and Black inks so that they can print effectively.
    Nov 16, 2010 | Lexmark Office Equipment & Supplies
    I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
    1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
    2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
    3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
    4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
    5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
    Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
    Canon i850-alignment
    Moski, When trying to align the printer you get a sheet of numbered lines. You want to choose the center most selection that your eyes see as straight lines. Whether they are horizontal or vertical it wants you to tell it which lines look the straightest. From there it will set itself up for proper printing. Tim
    Jan 28, 2007 | Canon i850 InkJet Photo Printer
    Lexmark C752dn Laser Printer Logo
    89 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
