Question about Toshiba 42HP66 42 in. LCD Television
42HP66 - Cracked the Glass plasma screen
I was moving my Toshiba 42HP66 plasma tv into my office and I had it laying flat on the floor temporarily with the screen facing straight up while I moved some other things off of the tv stand it was to go on. I accidently bumped a lamp off of my desk and it feel right on top of the plasma screen scratching the plastic screen and cracking the glass underneath the plastic screen. Is my plasma now worthless or is there a way to get this fixed at a reasonable price? If the repair cost $700 or $800 or more I don't think I should even bother.
  • Tony_tbone Feb 13, 2008
    Thank you Josh and C-Dog for the help. Ugh.
    Thank you Josh and C-Dog. :( ugh.
  • 113 Answers
Sorry to be the one to tell you but your tv is nothing more than a paperweight at this point. The panel would need to be replaced part number is 72784162 and I could not find anyone selling it for less than 2000 dollars. Since I know the tv is about 1500 or so on the shelf you are looking at just replacing it.
Josh
Posted on Feb 13, 2008
  • 84 Answers
It is worthless. The glass itself is the sealed plasma display unit. once it is cracked it will not work correctly. The most expensive part of the set.
C-Dog
I have a Toshiba 42HP66 plasma tv.it's developed 3 horizontal lines at top half of screen. What is the problem. Thanks
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
May 23, 2016 | Toshiba Televison & Video
Replacing glass screen on 50in plasma samsung
if your plasma tv is not gurantee and company is not going to repalace it the price of a plasma panel more or less is about 70 %
of a new plasma tv this means that if a plasma tv is 1000 usd you have to pay at least 700 usd
Oct 15, 2014 | Samsung PN42A450 Plasma TV
MY SCREEN INSIDE THE TV APPEARS TO BE CRACKED WHEN YOU TURN THE TV ON. IS IT FEASIBLE AND COST EFFICIENT TO REPAIR
It may look like it is cracked but it isn't. A plasma panel can't function if cracked as it would evacuate the gases contained in the panel. What you are seeing is most likely delamination of the screen. This sometimes happens on its own but usually occurs when the TV is moved or stored incorrectly. The elements of the panel actually detach themselves from each other and the bonding between them is what you see. This is assuming the glass screen on the outside portion of the panel hasn't been cracked.
Joe
Nov 08, 2010 | Philips Brilliance 420P 42 in EDTVReady...
My 42 in. 42HP66 Toshiba Plasma TV popped and screen went blank
One of your y driver almost go bad. For your future problem please visit my site athttp://billy-tech.blogspot.com/
May 07, 2010 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42" plasma tv 42HP66. All of a sudden, no picture.
Hello, You may have a bad power supply! Its hard to say! I need more info! please feel free to call or message me if you would like more help with your TV!
Thank you!
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Apr 07, 2009 | Toshiba 42HP66 42 in. LCD Television
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
Toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
Jul 12, 2008 | Toshiba 42HP66 42 in. LCD Television
Plasma tv
I have a 50 plasma Toshiba and since this morning it turns on and off every 20 seconds by itself. The control is not working either. When it's on it nakes a static sounds and then just shuts off. If anyone can lep me please do so.
Mar 13, 2008 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42HP66 42 in. LCD Television Logo
230 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
