Question about Everex StepNote LM7WE Notebook
Wont run BIOS
I bumped my computer it went out and it wouldnt boot. I took it to a friend of mine and he installed a new hard drive howevet the new hard drive is not registering and it will not run BIOS
  • dwhit33 Feb 13, 2008
    I will ask my buddy and find out
  • 145 Answers
Are you using delete to enter bios as the unit is powering up.
Posted on Feb 13, 2008
My lenovo got a new harddrive and won't boot at all not even bios what to do? It's a g 560
You have to recover your MBR looks like, but first you need to remove the hard drive and see if it will boot without the HDD installed then get back to me ok. Also sounds like the BIOS may have failed if it wont boot without the HDD installed. But first things first.
Apr 04, 2015 | Lenovo Computers & Internet
Do I need a new hard drive for my acer d260?
It sounds more like you haven't installed ubuntu correctly. Why do you think the drive is faulty, was it giving drive errors before you loaded ubuntu? Does the bios have s.m.a.r.t. disk checking enabled?
If you can get back into ubuntu perhaps by booting off an ubuntu disk you can check the disk - here's how How to run checkdisk
If not take the drive out get a sata to usb converter and run a disk checking utility on a friends machine
for example chkdsk space diskletter colon space / f
chkdsk e: /f
Microsoft Corporation Smartmontools Community Help Wiki
May 13, 2014 | Acer Aspire One D260 Netbook
Acer aspire 5517 is having problems loading the Operating system. when it try's to load it comes to a black screen that says that there is no bootable device connected. i restarted the computer and enabled...
have you tried looking for a windows label on the laptop that will tell you what version of windows is on it
The fact you are seeing two hard drives is probably because it is partitioned. The hard drive you tried to boot from to repair it , that is the system recovery partition the other partition is where your windows is installed
try pressing the ALT key & F10 together immediately after turning the laptop on
This should invoke the recovery partition to restore windows back to how you got it from the factory
NOTE THIS WILL DESTROY ALL DATA THAT WAS PREVIOUSLY ON THE COMPUTER
so anything on it will be wiped and it will be as you got it when it was purchased
If this helped you please vote for me
P.S. Other people please note how the poster explained there problem, in great detail and not just something like my laptop wont work
Feb 25, 2011 | Computers & Internet
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Dell optiplex gx280 won't boot up
you either have the boot priority in the bios off or you have improperly cabled your hard drive . perhaps you set it to boot to cd while installing the operating system and forgot to change the order back.
The floppy drive does not have to be present for the system to boot (if set to "not installed" in bios)
your boot devices are your cd/dvd rom and your harddrive.
Seeing as you've recently replaced the power supply , ime assuming you didnt dismantle the whole computer , just the power leads coming from the power supply, which means you only moved power , not data cables.
This would be the first thing to check -- power to the harddrive and cd rom, the 4 pin connector that sometimes connects to the motherboard and any data cables you might have bumped while changing the power cables. check these things and post here again.
Regards
Apr 01, 2009 | Dell OptiPlex GX280 PC Desktop
Cloned hard drive wont boot up
sir,
Check with bios settings. also check the cable if sata activate at bios. need to check bios itself.
Thanks Good Luck
Mar 23, 2009 | Acronis Migrate Easy 7.0 (AME7)
My computer wont boot because it wont automatically detect my har
Usually when your BIO's doesn't detect the hard drives is usually a good indicator that the hard drive has failed. In rare instants it is the motherboard. In the boot sequence it will only show the hard drives it sees if it doesn't see any then none will be shown. I would start with a new hard drive.
Hope this helps.
Mar 01, 2009 | Dell Optiplex GX60 PC Desktop
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Everex StepNote LM7WE Notebook Logo
91 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
