Question about Dell F3534 Touchpad
Touchpad going crazy...
I need help with my Dell Latitude D820. The touchpad will move on it's own to the right or to the left, either to the far upper right corner or the lower left corner of the screen. How can i fix this?
  • Engus Jul 20, 2008
    I have had the same problem. Most of the time I plug a portable wireless mouse in but when I can't this machine has a mind of its own. The left button seems to have heat seeking abilities. If I put my finger near it there is instant action and the pad tries to read ny mind but it is usually wrong.
    Can it be replaced with another type or adjusted for sensitivity?
  • 3 Answers
Set ur mouse button to default or reinstall ur drivers this may fix ur problem.
Posted on Feb 13, 2008
Pritamkoo7, do U have a Dell computer? I do and there is no easy solution - just type Dell touchpad problems in Google and see all the problems that people are having with all makes and models. I am extremely upset with Dell over this because some of these complaints date back to 2004 and they STILL haven't corrected it yet. Haven't found a solution yet - my cursor takes "trips" on it's own and the left button sometimes will not click - or acknowledge that it is being clicked - and I have found that clicking the right button and then clicking the left button again gets it working; temperarily. I need answers also.
Posted on Jun 17, 2008
I'm doing a repair installtion on my dell D820 laptop and I got a pop-up on Regional and Language options. The problem here is I can't move my cursor. I tried using the touchpad and even plugged in...
Please try using the D Pad (arrow keys) to navigate. Once the option is highlighted, press enter to change it. Please revert back with the results.
Sep 02, 2011 | Dell Latitude D820 Notebook
I have a new Dell Latitude E6410. While typing the cursor moves automatically causing inserting/erasing text. How do I fix this?
I'm assuming you are using some version of MS Windows.
I found this on the Dell support website;
  • Click Start.
  • In the Search box type main.cpl, click main.cpl in the list of programs.
  • In Windows XP click Run, type main.cpl in the box next to Open, click OK.
  • Click the Dell Touchpad tab.
  • Click on the picture of the touchpad.
  • Click Touchpad Settings.
  • Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  • Uncheck the box to the left of b>Tap to Click.
  • Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  • Click Apply, then click OK.
  • Click the X in the upper-right corner to close the Dell Touchpad Utility.
Hope this helps ;)
Feb 02, 2011 | Computers & Internet
How can I disable the mouse tapping function on my dell latitude e5400?
  1. Click Start.
  2. In the Search box type main.cpl, click main.cpl in the list of programs.
  3. Click the Dell Touchpad tab.
  4. Click on the picture of the touchpad.
  5. Click Touchpad Settings.
  6. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  7. Uncheck the box to the left of Tap to Click.
  8. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  9. Click Apply, then click OK.
  10. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Sep 23, 2010 | Dell Latitude E5400 Laptop
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Aug 31, 2010 | Dell Latitude E5400 Laptop
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
I have a dell latitude d600 and the cursur goes crazy on me alot and I cant figure out what to do to make it stop
Check the touchpad settings and ensure that palmcheck/Touchcheck is enabled.
Update the touchpad driver
May 25, 2010 | Dell Latitude D600 Notebook
Dell latitude touchpad mouse is sticking and right
you are facing a defective mouse touchpad...have it repaired
Feb 16, 2010 | Dell F3534 Touchpad
Touchpad right and left clickers womt work
this is due to the driver missing or uninstalation of the touchpad you must try to reinstall the driver again.
for any harware problem you can check the status in
DEVICE MANAGER present in CONTROL PANNEL(WINDOWS VISTA)
for
WINDOWS XP you can search this application in windows search.
Apr 20, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Computers & Internet Logo
1,972 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
