Question about Dayton G73 Utility Heater
Dayton G73 electric heater
Just had the electrician install it. it goes on for 3 minutes with the fan at low speed and stops for 5 minutes then goes on again for 3 minutes.
HELP
  • 1 more comment
  • GillesP Feb 13, 2008
    Thermostat is at maximum. Temperature is approx 35 in the garage.
  • Anonymous Feb 19, 2008
    I have several of these heaters, they work very well however the thermostat could be better designed, it is hard to tell where hi and lo are we usually have to turn it way down about 1/4 from low and it does cycle and the temp varys about 10-12 degrees before it kicks back on, we have had no problem with reliability and it travels down the road heating in a cargo trailer, no failures yet, been using them about 6 years and hundreds of thousands of miles
  • lstark295 Feb 25, 2009
    I bought the G73 used from a guy at work, he says it was used very little and works good. I wired it up in my garage and it is off more tnan it is on. runs for 2 minutes and off for five. I read in the directions that it will cycle when below 50 degrees, I ask how will it ever get to 50 degrees. I have heated my garage up to 70 with a torpedo heater in addition to the G73. when the torpedo was shut off the temp continued to drop in the garage. By the way the garage is fully insulated with the house on two sides. I left the G73 on at the end of one day when the garge was heated to 65 with the torpedo, and the next day it was 40 in there with an outside temp of 25. Any solutions, could I have some wires mixed up? I checked the eattage jumpers and they are on high.
I just got my G73.  It comes with a new note that says "below 50 degrees the fan will cycle randomly (and might seem like its not working correctly) but once it is above 50 it will cycle normally."  it uses that to let the element re-heat quickly to bring the room up to temp faster.
Posted on Dec 23, 2008
  • 2,336 Answers
Check the thermostat settings and try with different settings.
It sounds like is set at very low heat and the room is at that temperature.
Posted on Feb 13, 2008
Dayton g73 electric heater less than two months old and thermostat goes out any ideas
I WOULD TRY TO BYPASS THE THERMOSTAT TO MAKE SURE THE UNIT WORKS AND REPLACE THE THERMOSTAT IF IT DOES , SEE IF IT IS UNDER WARRENTY, MY GUESS WOULD BE THAT IT IS JUST DEFFECTIVE, AND YOU ARE TRYING TO FIND A CAUSE, THIER IS NO REAL CAUSE THAT I CAN THINK OF THAT WOULD BURN UP THE THERMOSTAT IF IT WAS OR HAS BEEN WORKING, GOOD LUCK
Jan 26, 2010 | Dayton G73 Utility Heater
Dayton G73 Utility Heater will not shut off until it reaches the high limit
Its probably trying to tell you something is wrong with me.. find the root cause!(like the fan motor is stopping and then the heat builds up and tripps the high limit switch!
Dec 22, 2009 | Dayton G73 Utility Heater
Can the G73 be hooked up to an wall thermostat and allow it to over ride the unit thermostat? I want to install this is in a greenhouse and would like to have the thermostat on the wall down lower and not...
Yes, but it will require some knowledge of electric to do that. You will need a line voltage thermostat and mostly like have to have that run a contactor that will be wired to bypass the heater thermostat. A good electrician should be able to to this for you very easily.
Nov 09, 2009 | Dayton G73 Utility Heater
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Installing a Dayton G73
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dayton G73 Utility Heater Logo
604 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
