Question about Ricoh Aficio SP C411DN Laser Printer
Ricoh SP C410DN error code SC306
Hi there, we have a question...we just had to replace four Photo Conduction Units on the our Ricoh SP C410DN color laser printer. Now the printer will not restart up. Says "error occurred sc306". Do you know anyone that knows these Ricoh units??? We've been waiting several days for a service call and getting impatient...Any help is appreciated...Kevin NJ
  • raprince Apr 30, 2008
    Pls i don't know what is wrong with my printer; when it is on it will show ALERT(red light) then it will show: service call SC545...
    Pls what can i do or how can i call service?
    I will like to get the reply also in my box: princeflames2002@yahoo.com
    Thanks!
    - Ronald A. Prince
  • dapojide Dec 31, 2008
    i have the same problem
  • 87 Answers
Reaseat the cyan photo conductor
Posted on Feb 23, 2008
I have ricoh laser printer aficio sp c420dn showing error code SC270
sc270 is an error with the shutter on the laser unit. Turn the machine completely off and then back on -- if the error doesn't clear, the shutter sensor or motor will likely need to be replaced.
Feb 16, 2011 | Ricoh Aficio SP C410DN Laser Printer
I have an Aficio SP C410DN with error code SC361. Any ideas what that could be? thanks.
Hi, SC361 is a Toner Density error in the Magenta PCU. Your best bet is to replace the Magenta PCU.
You could go in to the service menu, if you now how and do a TD Initialize on the magenta PCU - Service menu 3.801.004, but it may still not resolve the problem.
Go with the 1st, hope it helps.
Dec 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
I am getting an error message: replace PCU: color soon and my printer is not working at all. What does this mean?
you must replace all 3 color Priter Cartrige units, approx. $600 cost; slide in from left side of machine
Jul 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
Hi all, I have a problem with a Ricoh C410dn , the error code is SC396, what does it mean ? Or do you know where to get a service manual for this printer ? Thank you very much
sc396 is an overload error for the black drum motor. You can try removing and replacing the black drum and making sure nothing is obstructing its movement (like a scrap of paper stuck somewhere or a chipped gear). You might want to have a service technician take a look at it if you can't find anything, to see if the motor needs to be replaced.
Jun 04, 2010 | Ricoh Aficio SP C410DN Laser Printer
Error code sc490 on aficio sp c410dn
SC490 High Voltage Power High voltage output error Error signal is detected for 10 times consecutively. One of the DC bias outputs for each PCU is shorted or one of the transfer belt bias outputs for [Y], [M] and [C]. • Power leaking • Defective connection • Disconnected cable • Defective PCU • Defective High Voltage Power 1 1. Replace the High Voltage Power 1. 2. Reset the cables and components. 3. Replace the PCU.
Feb 11, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh SP c410DN - print dots verticaly down the page - I have clean the roller as instructed.
Notice what color the dots are. Most of the time you need to replace that color photoconductor.
Oct 29, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
Ricoh Aficio  SP C411DN Laser Printer Logo
1,628 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
