Back to:
Tags:
Motorola E680 Handheld
Motorola E680i not charging properly (by 3 users)
posted by Kiki11 on Feb 13, 2008
Hi, I have a Motorola E680i. While charging it, it fell and apparently few hours later when I checked the port (for the charger) it was a bit loose (didn't realise this when I took it off the charger). Since then I have not been able to use the charger cable to charge it. The USB cable works inconsistently - if I 'jiggle' the cord a bit and not disturb it, it 'may' charge. Last night when I did this I woke up this morning to find the phone blank and refusing to turn on. Took out the battery this evening and used a universal charger, tried it again and now it's working.
Help! I REALLY love this phone. Is it a battery problem or the port for the charger that is a problem?
Your assistance is gretaly appreciated.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by nyli, posted on Jun 07, 2008
i have same problem. the battery port. It cannot work. I bought universal cell phone battery charger and two extra battery. And it solved the problem.
Comment by nyli, posted on May 16, 2008
I have similar problem. How do i change the port???
Best Solution
posted on Mar 05, 2008
Helpful (85)
droppD
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
charge port prob lo...just change new port or do it ur self
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Motorola E680i not charging properly:
I don't want to Accept this solution
Solution #2
Not Rated (0)
alva06
Rank:Master Master
Rating: 86%, 10 votes
first see if you can get the port on the store. Or may be the glue can fix any cracks to make it work;) but advice on glue: use wisely ! If nothing works, contact me , anyway you have the USB charging system as backup
Thank You!
Can you Help with these PDAs problems?
how much it will cost me and where can i send it
I have a Motorola Blackberry H 700.  I turned on the...
how do i activate the tv for motorola e680? please help
i have mot e-680. my alarm doesnt work. unable java and...
You wrote: I think I had a similar problem when my phone...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
