Question about Symbol MC70
MC70 symbol stuck on warm boot screen..flicks on and off every 10-20 seconds.... and ideas...????
  • Anonymous Feb 26, 2008
    I have the same problem
I used the manual keys to get to the alignment screen...
But the unit would not hold the settings.
Posted on Aug 08, 2008
HOW DO YOU GET A ALLIGNMET SCREEN UP?
Posted on May 23, 2008
    Novelist:
  • 126 Answers
Have you every try to take the battery out and put it back in.
Posted on Apr 23, 2008
  • 6 more comments
  • KISHMA FOY Apr 24, 2008
    yes
    Motorola Support Associates are here to help you 24 hours a day, 7 days a week.
    To help us support you better, please locate your company's unique
    seven-digit site ID number and unit serial number before contacting
    Symbol, so we may respond to your needs appropriately.
    1.800.653.5350
    EDA shuts off. EDA is inactive. The EDA turns off after a period of inactivity. If the EDA is running
    on battery power, set this period from 1 to 5 minutes, in
    one-minute intervals. If the EDA is running on external power, set
    this period to 1, 2, 5, 10, 15, or 30 minutes.
    Check the Power window by selecting Start > Settings > System
    tab and tapping the Power icon. Select the Advanced tab and
    change the setting for a longer delay before the automatic shutoff
    feature activates.
    Battery is not
    inserted properly.
    Insert the battery properly. See Installing and Removing the Main
    Battery on page 1-3.
    Battery is depleted. Replace the battery.
    Resetting the EDA
    There are two reset functions, warm boot and cold boot. A warm boot restarts the EDA by closing all running
    programs. A cold boot also restarts the EDA, and also resets the clock. Data saved in flash memory or a memory
    card is not lost.
    Perform a warm boot first. If the EDA still does not respond, perform a cold boot.
    Performing a Warm Boot
    Hold down the Power button for approximately five seconds. As soon as the EDA starts to perform a warm boot
    release the Power button.
    Performing a Cold Boot
    To perform a cold boot:
    1. Simultaneously press the Power button and the 1 and 9 keys.
    2. The EDA initializes.
    Performing a Clean Boot
    A clean boot resets the EDA to the factory default settings. All data is the Application folder is retained. You must
    download the Clean Boot Package file from the Support Central and install on the EDA.
    NOTE When the EDA powers up after inserting a battery for the first time, the device boots and powers on
    automatically.
    CAUTION A clean boot should only be performed by an authorized system administrator. You must connect the EDA
    to AC power during a clean boot.
    Removing AC power from the EDA during a clean boot may render the EDA inoperable.
    To perform a clean boot:
    1. Download the Clean Boot Package from the Support Central web site. Follow the instructions included in the
    package for installing the package onto the EDA.
    2. Simultaneously press the Power button and the 1 and 9 keys.
    3. Immediately, as soon as the device starts to boot and before the splash screen is visible, press and hold the
    left scan button for a few seconds.
    4. Insert the EDA into a powered cradle.
    5. The EDA updates and then re-boots.
    6. Calibrate the screen.
    IF NONE OF THESE WORK JUST CALL MOTOROLA. SORRY
  • Mert Mahir Karasu
    Mert Mahir Karasu Jan 23, 2014
    this works,thanks
SOURCE:
Could you tell me what has to be done when the only item appearing on the screen is MC70?
Resetting the EDA
programs. A cold boot also restarts the EDA, and also resets the clock. Data saved in flash memory or a memory card is not lost.
Performing a Warm Boot - Soft reset
Hold down the Power button for approximately five seconds. As soon as the EDA starts to boot release the Power button.
Performing a Cold Boot - Hard reset
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
Dec 03, 2010 | Zebra Symbol MC70 HandHeld Mobile Computer...
I can't boot a Symbol MC9090.
She's Broken...contact your dealer or the Motorola Help Desk at 1-800-653-5350.
Oct 02, 2009 | Zebra Symbol Technologies MC909X-G Series...
97 grand am instrument cluster flicking
replace the gages their malfunctioning ,check the wires for they are grounded.
Jul 20, 2009 | 1997 Pontiac Grand Am
My MC9090-G scanner is stuck in boot mode. I've tried a cold boot and warm boot and nothing works.
Actually if it is continuously rebooting, it is usually because someone was holding down the trigger through a cold boot process. That's what puts it into this continuous reboot loop. To get out of it do a cold boot again (pop the battery part of the way out, hold down the power button and trigger simultaneously, and then push the battery back in while the power button and trigger are still down). But as soon as you push in the battery to the point where you hear it click, release the trigger. If you hold it in too long, the unit will start continuously rebooting.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
Nov 21, 2008 | Symbol MC9090-G LORAX MONO 64/ 64MB 53 VT...
Stuck in a Warm Boot Loop
download the cleanboot files here. upzip the 70XXcleanboot folder. copy the 4 files to an SD card. put the card in the device and cleanboot it (powerbutton + 1 + 9, then hold yellow scanner button).
It will boot
Sep 11, 2008 | Symbol MC70
Diference between Cold boot and warm boot
A warm boot restarts the mobile computer by closing all running programs. All data that is not saved is lost.
A cold boot also restarts the mobile computer, but erases all stored records and entries from RAM. In addition it returns formats,
preferences, and other settings to the factory default settings.
Apr 07, 2008 | Symbol MC1000 Barcode Scanner
Symbol MC70
Questions:
Have you tried the classic "hard boot"?
Do you have a WAN or LAN radio configuration?
Has the device worked for you in the past ... and no will not?
Until you answer my questions and I get back to you you might try pulling the battery out for 10 min or so... see if it reboots when you reinstall it
Jan 07, 2008 | Symbol MC70
Symbol MC70 Logo
5,344 people viewed this question
Top Symbol Computers & Internet Experts
Vish Iyer
Vish Iyer
Thomas F. Schneider
Mike Story
Level 1 Expert
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
