Question about RCA F36450 36" TV
Picture blurry When I turn on my RCA F36450 the picture is very dim for about 30 seconds, then gets bright, also after it brightens up like it should be, the edges get blurry,blurrier, and blurrier for about 10 to 15 seconds the super clear for about 10 seconds then starts over again. I did recently take it to a small tv shop because the tv went completely out and would not turn on. They fixed it, but shortly later, (after my 60 day warranty), this problem arose. Any suggestions? I install business alarms and also build custom PC's so I am tech savvy if you can tell me what to replace or repair. Thanks sl
  • slong Feb 13, 2008
    C-Dog...... would this make the picture turn blurry for about 10 seconds then turn super clear for about ten seconds? Also its not so bad that I cant watch tv on it but I definitely have trouble reading my cable guide. also what would cause it to be very dim for the first 20-30 seconds when I turn it on? does the flyback transformer have an adjustment knob or screw? Appreciate the help!
    Slong
  • 84 Answers
What was replaced by the repair shop? The blurriness may be out of focus. If so, the focus is controled by the flyback transformer. That connects to the picture tube at the top (anode cap).
C-Dog
Posted on Feb 13, 2008
  • Carl Manaloto
    Carl Manaloto Feb 14, 2008
    yes, the flyback has 2 adjustnebts on it. the top is focus the bottom is screen control.
    C-Dog
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
Put lights on picture brightens put lights off picture dims
Go to the menu, then select PICTURE or something similar. Then turn off "dynamic" or "automatic" on screen brightness.
The dynamic helps you save energy and always looks about the same contrast ratio. without, it seems too bright in the dark. It is actually a feature of higher priced televisions.
Jun 14, 2011 | LG Televison & Video
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
My 52" RCA projection, model
comon fault is one of the picture projection tubes is broken.not worth fixing
Mar 29, 2011 | RCA HD52W59 HDTV Projection Television
I'd like to brighten up the picture kinda dim samsung hl-s5686w what can i do?
Turn up contrast to 95 and turn down brightness accordingly. If it is oddly dim, you may have a problem with the backlight.
Jan 28, 2011 | Samsung HL-S5686W 56" HDTV
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Picture is dim and blurry
The screen probably needs to be degaussed, which will require either a degausser or a technician. Try turning the television off, and then unplugging it from the wall outlet. Then replug after 30 seconds and turn it back on. Also, try plugging any cables from a cable or satellite box into another set of in-ports on the back. If the problem persists, the screen needs to be degaussed.
Feb 22, 2008 | Philips 51PW9303 51" Rear Projection...
Problems with brightness on the hitachi 50v810
Yes, they dim as they age, and you've done well to get 3 years out of one.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Jan 02, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
RCA D32F750T TV
Did you adjust the two controls on the new flyback? The top one is almost always the focus control and the bottom is the G2/screen control (brightness) If you adjust the G2 do it until the picture looks normal, too high and you will get retrace lines through the picture.
Jan 25, 2007 | RCA D32F750T TV
RCA F36450 36" TV Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
