Question about Xerox Phaser 8560DN Laser Printer
Solid ink runs out
I have purchased 3 sets of solid ink cartridges in the past six months.. I barely get to pring 100 pages when I get the message that I need to get more solid color cartridges. I never turn the printer off but I still have to buy too much solid ink to justify continuing to use this printer. Any help?
    President:
  • 2,072 Answers
That was the first think I was going to suggest was not shutting it off or restarting the machine. Make sure the power save is off on the machine.
The only way I can tell you to resolve the cost is to go on a cost per page maintenance agreement. That way you pay a certain affordible cost per page and they supply the ink.
About the only way to get around the solid ink cost .
Posted on Feb 13, 2008
I have a HP 1610 all in one printer. It is going through black ink cartridges very quickly (94 HP ink cartridge purchased from amazon, 1 a month or about 100 pages). I do not print everyday and very...
If you are buying genuine cartridges, check the print settings, you may have it set to high resolution and for the wrong media type.
Genuine HP cartridges are fully filled, compatibles sometimes are not. 100 pages of plain text is ludicrous. I would refer this to Amazon and ask for a refund.
The only other problem may be with a leaking seal, but i would have thought that this would be apparent by now, as ink would have leaked visibly
Mar 29, 2011 | HP PSC 1610 All-In-One InkJet Printer
Tip
Ciss and refillable cartridge systems
Depending on printer brand and model, there are lots of ciss (continuous ink supply system) solutions to buy.<br /><br />Bare in mind, though, if you are planning to use printer heavily, there are other considerations you should think about:<br /><br />1. If not used regularly, an air bubble may occur and it takes a while to pop it up. Also ink may dry in certain area and it's a mess to resolve.<br /> <br />2. The ink supply (depending on supplier) may not be good as the original; color depth and durability wise.<br /><br />3. Cartridge recognition problems may occur from time to another, so it must be removed and inserted again.<br /><br />4. CISS system usually have a chip to fool the printer and it may fail with any liquid contact.<br /><br />5. ink pad inside printer fills quickly on heavy use, thus its wise to direct the pipe into an external tank (found inside and in the back of printer for Epsons) <br /><br />In conclusion, if you intend to have more than 100 pages/month, consider compatibles or refillable cartridges. ciss is good for +200 pages/month.<br /><br />e.g. (epson rx685 blanks out all 6 cartridges except for the black after 10x15 photo's in with high quality enabled)<br /><br /><span style="font-style: italic;">Please note that these tips are based on experience with 4-6 cartridge systems for Canon and Epson printers.</span><br /><br /><br />If you find this informative, kindly <span style="font-weight: bold;">vote positively</span> for me to continue sharing. Good luck and thanks.
on Nov 26, 2010 | Office Equipment & Supplies
I have gone through $100 in ink this month alone for my Lexmark 705 Pro Prevail. It prints like 20 word doc pages (not photos) and then it says it is empty again, and the cartridges need constant...
Check the settings of your printer, either in the software that came with it or the printing preferences in the Control Panel. If your ink tone is set too dark, it could be using a lot of ink. If this is not the case, then:
1) Clean the ink cartridges
2) Replace the ink cartridges as they may have expired. 3) Replace the printer and find one which uses cartridges that can perform more copies in a single fill.
Jan 24, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
My 620 printer (newly installed) will not print. It runs back forth but no ink shows,
If its all installed properly, and the test page doesn't pring properly, the only thing I can think of is that there's a problem with the cartridge.
Try taking out the ink cartriges and check that the celophane head cover has also been removed. If so, there could still be a cartridge issue and the only way you can test that is by buying more cartridges.
If you don't want to go down that route, if its less tha 12 months old, take it back to the shop and get them to replace it.
Mar 05, 2010 | Cameras
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
HP printers - remove and check cartridge. (Use it or lose it)
There is no solution for HP Printers being used very lightly - meaning "not for months" etc.
As a result, if you are stuck in this predicament - an HP inkjet, that you only need every few months - I instead suggest you set a calendar entry for once a week or more and run a test page.
The printer will "hopefully" not dry out by being periodically used - and the ink "wasted" will result in a LONGER cartridge life than if you had to throw out a cartridge.
There is also a time period, or sensing of the cartridge, that results in a wasteful cleaning cycle in which it pumps ink "down the drain", and I'd like to know how often to test print to avoid that.
My solution to my most recent problem was to "give up" and throw a new (black) cartridge on it and take the barely-used one out.
Jul 07, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Xerox Phaser  8560DN Laser Printer Logo
93 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
