Question about Microsoft Windows Vista Ultimate Edition
MP4 1GB n61217r1f.70
I have acquired the above player and although I have been supplied with a
Mini Disc I cannot get Laptop driver to program it.
My laptop keeps telling me - this driver used only for windows 98 the program must be exited- This laptop is about a year old.
  • dpeder2 Sep 21, 2008
    i have ta similar problem drivers included ar for windows 98
    machine is gl1502. manufacturers site is in Chinese. no idea were to find drivers
  • orestes484 Dec 23, 2008
    I have MP4 GL1502 manufactured in China and i can't run the driver A1 supply together with the MP 4, because my computer have Window Vista and the another have XP but the driver no run. I don't whats is the solution. Thanks in advance.
  • 152 Answers
If you are using windows vista forget about using that player in ur laptop dude.... vista has compatibility issues... many softwares which used to run well in windows xp are not running in vista,,,, try finding the driver for the player for vista,,,...
Posted on Feb 13, 2008
Problem with driver on 64bit laptop: need Help
You bought an MD recorder that only records from computers via a proprietary Sony program -- Net MD.
Here is the owners manual - http://www.minidisc.org/manuals/sony/sonysite/MDS-NT1.pdf .
Sony's website will help.
Sep 19, 2012 | Sony MDS-NT1 Mini Disc Player
How do I load flashplayer on my Archos 70
The achois is enabled to display media. The computer that would feed media into the achois device may should be undated with flash player also acquireable on the internet. Once the computer has flash player capacities or programs installed, the achos player becomes compartible with computer and media requiring transfers becomes achievable.
Feb 08, 2011 | Archos 70 Internet Tablet
Din unlock c-17 on sony mini disc
If “Din Unlock” flashes in the display
• The digital program source is not connected as you set
with INPUT
To continue, connect the program source properly.
• The program source is not on.
Turn on the program source.
May 11, 2010 | Sony MDS-JB940 Mini Disc Player
Sony MDS-JE440 mini disc,single play
If there is a "PROGRAM" button, then you just turn on "program", rotate the knob to what track you want and then hit ENTER. Then when you hit 'play' it will only play back that track. You'll have to repeat this for every track or manually hit the PAUSE button between tracks if you program more than one.
Nov 10, 2009 | Sony MDS-JE440 Mini Disc Player
I want to record music from my laptop to my sony mini disc recorder and i dont know how to
using a mini plug for both laptop / mini player...plug into headphones on laptop and into line in mini......when ready press play on laptop while also pressing record on mini........note have your play list ready for continuous recording...(you can always edit later)
Oct 07, 2009 | Sony Net MD Walkman MZ-N510 MiniDisc...
Every time I load a disc the words 'disc load error' appear
Inside all MD players are a number of small pinswitches. These sense whether the MD is correctly inserted, whether the record protection tab is activated and whether the protective slide on the MD has retracted after MD insertion. On Other (portable) MD playback devices will also have a pinswitch which checks that the lid has been closed, but yours is slot loading so does not have this.
Pinswitches do not last forever as the internal parts can fail due to fatigue or due to misuse, and in every MD player which I've examined with the symptoms you describe the fault has either been a pinswitch or a faulty solder joint to the switch.
Without examining the unit though it's not possible for me to narrow down the fault any further but if you have basic electrical skills and tools you can use a continuity meter across each pinswitch to determine which one is not working correctly.
The part is cheap: original spares are usually unavailable but can normally be replaced with a generic item or bypassed altogether if the user is prepared to accept minor losses in overall functionality.
Note that a good used MDS-JE480 is still relatively easy to find: my first one cost me just £30 on eBay less than two years ago and since then I've acquired another which was listed on FreeCycle for the princely sum of zilch. Yamaha and Kenwood units are also knocking around although few of these have the MDLP capability of the JE-480. So don't bother with spending much on repairing your current unit without looking for another replacement first as it's likely to be the cheaper option.
Sep 18, 2009 | Sony MDS-JE480 Mini Disc Player
Mini DVD-R player for PC
What contents do you have on the ini disc?
Nov 09, 2008 | Televison & Video
Disc Read Error Sony DVD Handycam
I am just throwing these out there as food for thought. Make sure you ended the recording on that other side. If a DVD is left open(meaning more could be written to it) other dvd players have a hard time reading the info. Put in one of the 2 sided disc's that worked. how does the camera recognize the disc? Then insert the troubled disc and see if the disc info is being read the same. i.e. disk size, manufactuer, open/closed? Check for a firmware upgrade for your DVD burner/player(s). Let me know how things work out. Tim
Mar 05, 2007 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
Microsoft Windows Vista Ultimate Edition Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
