Question about KitchenAid KAWS850LE Top Load Washer
Kitchenaid top load washer
When I pull out the start knob, the water will not turn on unless I am pushing in the disc around the knob. Is this some kind of short or is there a bad connection?
    President:
  • 1,314 Answers
Could be either take out the two screws at the base of the control panel and raise it up after you back the screws out pull the panel forward then lift it up its on hinges check all the connectors next you will see a black plastic piece in the center of the timer pry it loose with a small screw driver till it extends but is not all the way off this will release the control knob make sure the inner ring is on the shaft properly then posh the knob on tight and push the plastic tab back in if that doesn't fix it replace the timer
Posted on Feb 13, 2008
How many times do you turn knob on timer to set
You have to push the knob in to set it for the program you want then push it in to start the machine . You can pull the knob out at any time to stop the machine .
Apr 29, 2014 | GE WBSR3140DW Top Load Washer
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Older style kenmore top load washer wont do anything....
This machine has an on/off switch built into the timer that is activated when you push/pull the knob.
Either something therein is worn or broken causing this switch to not function. I myself could probably fix this problem and have done so on occasion, but an inexperienced person might find it to be a challenge.
Replacing this timer is expensive unless you can find a used part somewhere.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Can't get the push-pull washer control knob off
push the knob in then turn counter clockwise it does not push on it screws on
Jul 10, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
Washer wont complete cycle. its full of water and I cant drain it
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
Nov 30, 2008 | Kenmore 24902 Top Load Washer
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Dec 08, 2007 | Maytag Atlantis MAV6000 Top Load Washer
KitchenAid KAWS850LE Top Load Washer Logo
57 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
