Closed caption in middle of screen
I recently went to buy a 32 inch hdtv. I do not have cable or satillite so I use the air waves. When I turned any of them ( various mfgs ) to an airwave station and turned on closed captions, every one appeared in the middle of the screen. My daughter is hard of hearing and I need this to work. Any brands or models without this problem? Thanks
  • Capt71 Jul 26, 2011
    I have 2 LG LCD TVs at home that have the same problem. This is very annoying. Does anyone know of a fix (or even a potential cause to be fixed)?
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
ok had to post this one with reference to the above problems
My area St Augustine Fl. .. COMCAST (THOSE PAIN IN THE A--) SERVICE INSTALLED A NEW BOX IN MY HOME THE OTHER DAY ... I KEEP SEEING the box go thru dowmloads
then the very next day I started to see the colosed caption across my screen
SOLUTION ... with tv on and box on ( be in cable mode) press MENU on cable remote ,press power button, press menu again, look at screen and where it says caption make sure it is disabled
Mine was enabled ... change it and problem fixed ... I spoke to comcast finally after trying all day and they confirmed that with their new down loads to box it triggered the CAPTION to be ON
anyway problem was fixed ...
I read all prevoius posts and tried them all ... so may be this will work for problem that someone is having as of 10-9-2008 ( I could not believe that they could do that but they sure can COMCAST is just a PAIN in the A--
thanks to all who post solutions and I had to do my share and maybe be able to help someone else.
Posted on Oct 10, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
  • 14 Answers
SOURCE: I can not get closed captioning on my vizio VO42L
If you are using a HD cable box then this would be setup in the cable box itself.
Example:
With a Motorola Cable box, you would turn it off and press the menu button (with the receiver off and TV on). This will bring up a menu that will allow you to adjust your digital closed caption settings.
If you do not have a Motorola cable box that I would refer to the manual or call the cable company.
Posted on Apr 05, 2009
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
There is a large black rectangle in the middle of the screen. It goes away for a second when I press the EXIT button on the remote and for about 4 seconds when I press the RECALL button on the remote. ...
This is a text box. This can be turned off under the closed captioning. There should be a cc button on your remote or the closed captioning features can be accessed from your television's menu. Turn closed captioning completely off to get rid of these text boxes.
Keep in mind that closed captioning can also come from your cable box or satellite receiver as well.
Sep 28, 2010 | Toshiba 32A33 32" TV
I have a black box going across my screen with blue numbers it will not go away. I have an emerson 32in hdtv flat screen
Make sure closed captioning is turned off on the TV as well as your cable box or satellite receiver (if you are using them and they have that feature). Captioning is probably on and set for text mode.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Closed caption wont turn off
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
May 07, 2008 | Vizio L32 32 in. LCD HDTV
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
BLACK SQUARE IN THE MIDDLE OF THE SCREEN
Find menu selection for closed caption. Note TEXT box ......Step through selections in that menu until you see text change to
closed caption and then select off.....Hope that helps....T.
Nov 04, 2007 | Hitachi 51F510 51" Rear Projection...
Black square in the middle of my viewing screen.
you have accendly turned on closed caption. the closed caption you have tured on is not the normal closed caption we are used to . it is called colsed caption text. either on your remote or in you manu, find the way to turn off cc & you should work ok. good luck.
Jan 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
856 people viewed this question
Top Televison & Video Experts
