FixYa.com
Tags:
Jensen JER-321 Remote Control
Remote not sending signal to TV (by 2 users)
posted by Molly Me on Feb 13, 2008
When
I push a button on the remote (JER 321) the power button goes red but nothing happens to the TV. The signals are not being sent/recieved. I sat on it for a second and that might be what caused the problem.
What can i do to fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by andy_garcia1, posted on Aug 04, 2008
i need the codes of my jensen remote for program my tv
Best Solution
posted on Jun 21, 2008
FixYa! (100)
superdaintyk
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I had the same problem-- again, after sitting on it for a minute or so. I think what happened is I un-saved the code for my television. I found these instructions to re-code the remote, and by following them, fixed the problem-- I now have a fully functioning remote control. Hope this works for you, too!
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 13, 2008
Not Rated (0)
premtech
Rank:Guru Guru
Rating: 89%, 811 votes
Molly,
First lets figure out if the remote is send or not.. Do you have a web cam? If so bring-up the cam on your screen so you can see yourself on the computer.. Now poin the remote at the cam lens and start pressing buttons. If you see a light on the screen eminating from the remote the remote is functioning...
Only other way might be have it tested at a local radio shack. They used to have cards for that - don't know if they still do - but wouldn't hurt to ask..
Let me know what you find and we'll go from there..
Bill
Can you Help with these Remote Controls problems?
REMOTE CONTROL
my reote does not have set up Answer This...
CODE FOR HITACHI TV
i lost the codes can someone... Answer This...
how to congig remote with
how to congig remote with my... Answer This...
Remote codes do not work
The remote codes for my Philips... Answer This...
Jensen JER-321
i dont have the remote control... Answer This...
Repair Service
Find Remote Control Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
